86' A/C Clutch works only when jumped??
Old 10-15-2012, 11:46 PM
spideynut's Avatar
So my a/c stopped working. I jumped the hot lead form the clutch and YES the a/c blows cold. So I replaced the relay no fix, blower relay no go. Bypassed low pressure switch and nothing. Anything else before I call the mobile ac guy. Hate to pay 100 bux to find out its a hidden relay or something.
Old 10-16-2012, 07:56 PM
BigBluePile's Avatar
Might be the controller
Old 10-23-2012, 11:49 PM
spideynut's Avatar
What does that thing do? We swaped a ac switch last night no go. Im just going to assume its low I gave the low side a little pop on the valve it had presure. Its going to paint on friday so I wont be able to mess with it for about a month.
Old 10-24-2012, 05:48 AM
vasinvictor's Avatar
Just because it had pressure on it doesn't mean the pressures are high enough. Get a can and put in it. Might have to jump the compressor to get it to "take". Other than that, the A/C button can be bad. Are you applying 12v to the A/C trigger wire to "jump" it?
Old 10-24-2012, 09:28 AM
spideynut's Avatar
Ya I'm using a 12v source. Once I hook it up the clutch locks up and cold air comes blowing out. I'm just about ready to leave the jumper on! I can't find a can of r12 or I would give it a blast.
Old 10-24-2012, 09:32 AM
Hard to find r12. Might find something compatible like Freeze12. Or just buy the r134a fittings from Walmart for like $50 and usually includes a can or refrigerant.
Old 10-24-2012, 04:14 PM
z31freakify's Avatar
had the same problem the whole time the wire that goes to the AC comp was torn, check it first it might be cut from somewhere
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Whatever123
09-30-2015 12:12 AM
Kalihi,HI
07-09-2015 04:29 PM
bryan34w
07-06-2015 05:53 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: 86' A/C Clutch works only when jumped??
