86 4Runner starts and then dies
Old 01-09-2012, 08:22 PM
andlours's Avatar
So this has been happening for a while with my 4Runner. It only happens after it's sat for about 5 hours. I turn the key and the engine cranks, it catches and then immediately dies. After I do it a few more times it will finally fully start. Also, if i give it gas at the start it'll start first time, every time. I've heard about cold start injectors going bad, so i recently pulled mine out and gave it a thorough cleaning, but I've noticed no difference. Could my CSI just be completely bad or is there another issue that I'm missing?
Thanks,
Andy
Old 01-09-2012, 08:47 PM
BMcEL's Avatar
Test/clean the AFM. Sounds like the vane isn't opening enough. That would explain it starting when you give it some throttle...more air to push the vane open.
Old 01-14-2012, 11:11 AM
andlours's Avatar
Well, I recently got an '82 Supra AFM, but I don't think that's necessarily the problem, because it did the same thing before I swapped it out for the new one. Any other ideas of what may be going wrong? If this helps at all, it also idles really low at start up. I don't know of the two are related though.
Old 01-14-2012, 03:49 PM
mattches's Avatar
Did you check for voltage at the CSI? Or try taking the CSI out and sticking it in a jar while you crank it, see if it shooting out gas? If it is working okay then maybe a throttle position sensor issue, or a loose vacuum hose?
Does it have any problems while it is running? Like surging, stalling, missing? Error codes?
Old 01-23-2012, 06:21 PM
andlours's Avatar
Well i haven't gotten a chance to look at everything quite yet, but ill certainly go through and check everything. I'll let you know what i find.
91toybeater
12-27-2015 07:46 PM
puffin04
07-10-2015 09:17 PM
MadMax48
07-03-2015 08:26 AM
sonic concepts
07-01-2015 02:33 PM
slider417
06-22-2015 10:18 AM
Quick Reply: 86 4Runner starts and then dies
