86 22re WEIRD sound
Old 08-12-2014, 11:20 AM
punks_is_4x4's Avatar
86 22re WEIRD sound
So this is my Dd and I usually only have to drive 5 mins away from the house to work all week. Well I have been having problems with my tps and lugging and my engine will die and won't start up for a min or 2 also burns extremely rich. I believe it's my tps. The strange sound tho only happens at 3k rpm or higher it almost sounds like water it's so hard to explain it sounds like a pool of water under my dash that's being shooken around. Does any one have any ideas. At first I thought something bursted and there would be oil every where or something nothing has popped open it's the strangest sound I've ever heard from any vehicle. I checked ny trouble codes I got 4 5 and 7. The one o2 sensor I know of its right off the exhaust manifold the thermo sensor broke off the coolant intake and just need to splice a new cap and the tps is a new one for me
Old 08-12-2014, 03:37 PM
Rerunn's Avatar
The sensor issues is likely your running rich problem. The water in the dash sounds like you have have in the heatercore. Crank the truck up and chit the heat on all the way with the blower about 1/3 the way on and try bleeding the cooling system
Old 08-12-2014, 05:08 PM
Jameshpulse's Avatar
I had water get in through my snorkel in a bad rain. I heard that same sound.
Old 08-13-2014, 04:11 PM
It might be rain in there I doubt it tho. I'll try and heat it up and run the heat could it air in the coolant from when i took the coolant intake to try and take off my tps ?
Old 08-13-2014, 04:20 PM
Rerunn's Avatar
That's is what I am thinking
Old 08-13-2014, 06:20 PM
How would I bleed the coolant would it be where u drain the coolant? If I'm gonna do this I want to make sure to take the tps off when I do it because I need to get it off and check it.
I have 2 questions
1 last night on 22reperformance I read that the early 22re's should be ran with the green prestone stuff. I recently flushed the whole coolant system and replaced it with stock Toyota coolant. I haven't noticed any over heating or anything just wondering if I'm gonna do long term damage using stock Toyota fluid.
I have tryed to get the tps off and can't get any screw driver on there because of the position the steel vacuum lines are in the way I've tryed using the s shaped one's it was to big. Any suggestions pics of it being done would help
Thanks in advance
Old 08-19-2014, 02:24 PM
has any one any ideas about these questions
Any help is much appreciated
Old 08-20-2014, 06:23 PM
So today I uninsured my truck I spent 2 hours trying to get to work because it wouldn't stay running . I'm not sure what the sound is yet but when I checked my radiator today and seemed extremely dry and I haven't noticed any leak espesially that much so time to drain my oil and see if its milky I'm praying it's not cuz I have not the experience to rebuild my engine so we will see tomorrow !
Old 11-19-2014, 06:29 AM
It was a bad thermostat switch on top of the thermostat housing
montanatruck
02-26-2017 07:07 AM
coleypull15
11-03-2015 07:41 AM
yourrealdad
07-21-2015 11:13 AM
PlayAwhile
07-20-2015 11:36 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: 86 22re WEIRD sound
