5.29 rear pinion bearing
i was in the process of replacing the front and rear pinion bearings when i noticed that the rear bearing just slid right off. its supposed to be pressed on and off right? if thats the case, do you think the bearing has just gotten stretched or do i need to get a new pinion as well? ive searched for about an hour trying to find what brand gears i have, with no luck! the numbers on the pinion are as followed.. 14283 t529 g10. im clueless.
try the new bearing if it is snug but still slides on fairly easy you may be able to use some sleeve retainer on it to keep it from spinning. how does the surface look on the pinion, is it worn from the bearing spinning?
Sorry, its shot. Its supposed to be tight for a reason. You could have a machine shop knurl the pinion shaft so the bearing is tight again; but its not going to be centered properly and will fail anyway. Best thing to do is buy new gears. Pick a brand or buy from a reputable dealer. Also see Zuk's website, he has his favorites and you cannot go wrong following his advice.
thanks. yeah im looking for new gears now, i was looking around on here to see what the best ones are. ill check him out and see what hes got on his site. i was looking at the trail-gear. they are fairly cheap. but with something like this price is not something im worried about.
the1998sr5
15
07-14-2020 08:35 PM
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
