4x4 quit help?
Old 11-26-2009, 01:02 PM
82odyota's Avatar
4x4 quit help?
my buddies 90 four wheel drive quit working it will go into gear in the case but it no longer has four wheel drive any common problems with these trucks im not very up to date on much thast not first gen so any ideas will help thanks
Old 11-26-2009, 01:31 PM
peow130's Avatar
Well uhhh.
Hubs locked?
Driveline in?
there could be a ton of things up..
Old 11-26-2009, 01:58 PM
bain's Avatar
id say make sure both hubs are locked
Old 11-26-2009, 09:59 PM
abecedarian's Avatar
ADD? Getting vacuum to the servo so the sleeve on the front differential engages?
Old 11-26-2009, 11:49 PM
livetoride88's Avatar
my 91 did the samw thing the easy fix is to install locking hubs then u can run a longer bolt into the detent hole on the bottom of the add shifter and the bolt will hold it in the lock or 4x4 position the use the locking hubs to engage or disengage the front axle
skebe22RTE
07-31-2015 02:03 PM
pyramid
07-29-2015 06:53 AM
Yota.Jay
07-26-2015 05:50 PM
mYnAmEiSmUd
07-20-2015 06:48 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: 4x4 quit help?
