4 wheel disc break pickup help
does anyone know where to find a kit for 4 wheel disc breaks for a toyota 8 inch read with drums? either a kit or a parts list that bolt on im not sure where to start?
dude forget the LC kit... custom rotors custom brake lines I dont think you want to deal with that when something goes wrong.
stay all toyota
https://www.yotatech.com/forums/f116...nstall-191482/
stay all toyota
To help answer your question, it would be good to know a little more about why you want to convert to discs. Because you heard they stop better on the internet? Drum brakes actually do have more stopping power. Discs are easier to live with though - easier to adjust, easier to change pads, lighter, etc.
If you 'wheel your truck hard, I recommend converting to full float:
http://frontrangeoffroadfab.com/nfos...f9b44660ff843e
As you can see in the post above, the big problem is maintaining the ebrake and there are a number of ways to do that - all with their own drawbacks. Be sure to do plenty of research on tcase ebrakes - they are VERY sensitive to setup and breakin!
Here is a picture before i put it back in the shop last week
-Solid rotors single case no gears no front drive shaft 8 inches in the front 38s
-with the new lift and michlins and duel cases i need to upgrade my breaks i just bought the stuff for the front fj60 front rotors and IFS v6 calipers now i need to redo the rear.
i offer a all toyota rear disc brake swap kit, or just the brackets
https://www.yotatech.com/forums/f37/...rakets-179881/
Because in the stock setup, there is really only one press-fit bearing holding the wheel on and the axleshaft bears both the drive torque and the weight of the truck. With the size (and especially the weight) of the tires you are looking at, the reliability of having 2 tapered roller bearings holding the wheel onto a spindle would be a VERY good idea. With a FF setup, the spindle bears the weight of the truck and the axleshaft bears the torque.
skoti89
07-06-2015 07:45 PM
