3VZE engine wire routing?
Hola amigos,
I'm done with my 3VZE, R150F and VF1A rebuild and ready to stick them back in the truck today. One remaining question is, how is the engine wire routed from the right side? The transmission has several points to mount the wire, but I can't seem to divine how it's intended to go.
Here are some pics to refer to, as well as one of the completed work, woo hoo!
Thanks for all suggestions.
Got it all done, and changed the routing just a little bit so that the engine can be pulled without having to either unplug the engine wire from the transmission or open the A/C line. Took quite a bit of sleuthing, since there is quite a number of little wiring harness retainers that keep it in place, most importantly keeping it from the exhaust. Same deal with the hoses, of course. It's pretty cool to be able to look between the engine and the fender apron and feel like it's semi-neatly laid out.
steve miller
10-10-2015 01:40 AM
