3rd swap
3rd swap
So my 93 needs a new rear diff, I bought a used 130k rear end from another 93, my 93 however has an abs sensor in the top of the 3rd, the other 93 has 2 sensors..1 at each wheel. they are both 4.88's or at least I think.. both had the g144 code on the door jam... my question is... how do I make it work, without swapping carriers? Will I have to drill holes? Or... can I just tape the sensor up out of the way, and call it a day? I have no use for rear abs anyway, cuz the rear brakes dont work.
T.I.A
T.I.A
Well you have a few options.
1. Remove the sensor and sell for profit (they can fetch around 30 bucks). Replace it with a brass plug.
2. Snip the wire off and leave it.
I would just snip off the wire. These things are notorious for snapping in half when removing. This usually requires removing the ring gear to get the peice out.
I have switched 3rds a couple times... and never had this prob, I gently pry it out with a flathead till I can pull it out..... So running without it wont matter? If thats the case... I'll just tape it some where and save incase I need it later for a sticker.
cool...thanks... anyone know why these 2 are different? I have seen many of these runners 93 and up, and have never seen this setup before, could it be that the donor was a limited? I didnt see any limited emblems on it tho. ALso I did notice the master, and abs booster was different on this thing. something yota changed mid year?
me either... thats Y I thought it was weird. even more so considering they are the same year, and everything else is the same... except the donor had leather, a power roof, and manual locking hubs(which someone got to before me)
Yeah.. whats even worse... the truck only has 130k, and has been sitting in this bone yard for 3 years... it was retired due to a bad tranny... motor and all was still good.... im getting the heads, and everything up for $200
Who retires a fine yota like that because of a tranny??? o well... worked out for me
believe me... I have thought long and hard about the locker... however, my wife drives the 93 now, and if I put a locker in...im gonna wheel it... and then she will get mad!! lol
LOL...She may drive it... but it's still my truck... this means... when the tar is white, she stays home... or calls for a ride...lol had too many chicks wreck my vehicles in the snow...lol
Well, either way, its locked (at least one is) and thats what matters ! lol i love the locker.
Yea i hear what you are saying about letting women drive, well for that matter, noone drives my truck except me! (unless the girl is hot and there is a reward after, right????)
jerusry
10-19-2015 05:28 PM
