347 V8 4Runner - Updated
Old 07-20-2008, 05:04 AM
JD
JD's Avatar
Guys, I'm in the process of building a new 347 stroker engine as the current one has been in my 4Runner since 1993 and done in excess of 270,000klms so its time for a refresh
The new engine will have a custom cam designed for mpg as I do across Oz trips etc so I took a couple of vids for record purposes before she comes out as the new one will idle like a cat
Click the square in the bottom right corner for full screen.
Old 07-20-2008, 10:48 AM
sloth!'s Avatar
what trans do you run? How are the axles holding up to the power?
Old 07-20-2008, 05:34 PM
JD
JD's Avatar
Supra R154 with a 37% overdrive.
Axles are Toyota but splines recut to Dana44 as I fitted a Dana44 third member so I could fit a Detroit Electrac. Have an ARB air locker in the front.
I will be using this custom injection I fabbed and the AFR 185 alloy heads on the new 347.
Old 07-20-2008, 05:40 PM
TOYOTA 1's Avatar
nice.. ive seen a 347 in action.. he was shifting at 7,500rpm, and said it would easiely turn 8,000. it was bad ass. im shure yours is to. how high do you rev yours?
Old 07-20-2008, 05:43 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
First time I've seen and heard of a ford powerplant in a Toy. Nice rig
Old 07-20-2008, 05:49 PM
TORTIS's Avatar
i bet it is hot in that engine bay.
TOYOTA 1's Avatar
yea probably around 190.
Old 07-20-2008, 06:56 PM
SLOWBOOST's Avatar
im partial to 331 and turbo...atleast thats whats under my hood in my mustang.
looks good though, im jealous for sure.
Old 07-20-2008, 07:06 PM
JD
JD's Avatar
Originally Posted by TOYOTA 1
............ how high do you rev yours?
The ecu limits it to 6250rpm but I run an MSD6AL so it can be overridden but really no need to go higher as it is a 4wd and the current engine is a tad over 300RWHP. I will be using a custom mpg and torque cam in the 347.
It will cruise all day at only 3000rpm
Old 07-21-2008, 03:50 PM
sloth!'s Avatar
do you ever use our truck to pull trailers or ever work it hard? I am thinking about going to a v8 in my t100 but I am not sure if the v6 rear end can handle the torque while towing a decent size trailer.
Old 07-22-2008, 03:28 AM
JD
JD's Avatar
Wouldn't be a problem. But if you want to do constant burnouts etc you might have some issues
Prior to fitting the Dana44 I never had any issues with the Toy diff and it was the 4cyl version with the smaller bearings etc and besides normal 4wd I've also towed a heavy V8 inboard speedboat numerous times.
Old 07-22-2008, 11:26 AM
RunnerUp's Avatar
that thing sounds sick, in the best way possible!!
Old 07-22-2008, 12:26 PM
apalmer1's Avatar
refreshing to see such an orriginal powerplant in a clean rig. very nice installation looks factory
Old 07-22-2008, 12:53 PM
just a 22re's Avatar
dangit i dont have any speakers on this computer but my god thats is and will only be the time i ever say this!!!
man that ford powerplant looks good!
oh man i feel sick now, dangit you took my cherry!!!
Old 07-22-2008, 01:07 PM
Kiwipushrod's Avatar
Hey JD,
Looks like another gearhead wrecked a perfectly good toyota
347c.i., MPG Cam specs?
Kiwi
Old 07-22-2008, 09:53 PM
JD
JD's Avatar
just a 22re
You need to check it out with a speaker pc
kiwipushrod
Mate, I did this conversion back in 1993 when my Toy was still under factory warranty
Since then I’ve made many changes to the engine culminating in what you see now but the bottom end has now done in excess of 270,000klms so its time for a refresh
I'm currently building up a 347 and recently finished the block prep
These are some of the new parts which include
Scat 9000 lightweight stroker crank
Special size Probe forged pistons with perfect seal moly rings.
Special size Probe lightweight rods
Clevite 77 bearings
Romac balancer
Ford Roller lifters
Ford SVO Oil pump drive
Ford SVO mini windage tray
Mellings oil pump
Moroso oil pick up
Pavtek alloy mains girdle
ARP complete engine stud kit
Extreme chrome moly flywheel
Seco pressure plate
Aisin HD truck clutch
Fel Pro gaskets
Ford 90mm Lightning SVO truck MAF
Accufab 80mm race series throttle body
Bosch 36lb injectors
Ford SVO/Rouse Racing HI-VO NASCAR timing chain set
Custom ground US camshaft,springs,titanium retainers and locks.
Also recently finished fully polishing the Scat crank
Have also fabbed a new alloy airbox for the larger MAF
Modified another sump to clear the front diff.
Also using another engine block I’ve done a complete revision of the front accessory brackets to use a Ford p/s and a/c pump and alternator. Only hybrid is the LS1 tensioner
Still got a lot to do but I'll get there
Old 07-22-2008, 11:45 PM
Jay351's Avatar
mmmhmm. That sounds great. Get some clips outside of you going through some gears
Old 07-23-2008, 08:49 AM
Hey JD,
Looking Great, I like the chamferd crankwheights on the Scat, polishing them can only help windage, very cool. I thought only old hotrodders knew about those tricks, lol
Are the #1, #2, rod bearings worn on the 270k motor? Or do You have it apart yet?
Spec's on Your custom grind?
If I keep reading this thread, I'm definately going to have to Step Up in the Craftmanship dept.
My ifs pan
Keep it up!
Thanks, Kiwi
edit; Exellent Bracket Work.
Old 07-23-2008, 10:48 AM
Strings's Avatar
What did it take to swap in the supra Transmission? Do you have any pics of it?
Old 07-23-2008, 10:35 PM
JD
JD's Avatar
Except for the input shaft length being 30mm longer and different gear ratios the Supra R154 is exactly the same as a R150/151 V6 4runner trans so it’s just a simple case of swapping the longer output shaft with a R150/151 shorter version and it will bolt straight up to any R series intermediate housing.
I used the R154 as it has slightly better gear ratios for my V8 and a factory 25% overdrive compared to the R150/151 17% and I found by swapping in the overdrive gears from a R150/151 you get a 37% overdrive, which I did
I had a custom bell housing made to fit the Ford and longer input shaft R154.
But I did some mods so I could get the gear levers better positioned etc. These are old pics but still useful.
http://members.iinet.net.au/~ozrunner/5Speed.html
Kiwi
Nope yet to pull the existing engine so I've no idea but I wouldn't think this will be an issue.
The cam is a Jay Allen custom cam built to suit my 4Runners weight, engine use etc and I'm not aware of the protocols re custom cams etc but my view is as it was ground especially for me by Jay and paid for accordingly, it's numbers etc are Jay's intellectual property so if you want one, pay for it
Quick Reply: 347 V8 4Runner - Updated
