33x12.5 rub?
1 Post
33x12.5 rub?
Hey If I get a 2" Toytec lift could I run 33x12.5x15 without rubbing at all? What backspacing would I need? I'm either getting the toytec lift which is BJ Spacers and AAL, or Shackles in the rear.. Which should I do? Shackles or AAL? I'm getting Pro-Comp shocks also.. Just wanted to know if it would rub or not, If it rub's I'll do some pounding and a small BL..
yes they will rub. get the 3in with probably a 1in body lift and you'll be good. and get 3.5 to 3.75 in backspacing for that wide of a tire to clear the a-arms.
The body lift, though, will help.
Fred
myotherrideisayoshi
09-29-2015 05:41 AM
