3.4 swap or lexus v8
Old 12-03-2008, 09:47 PM
country boy's Avatar
im just trying to get some advice on engine swaps and what you guys think is better any advice much appreciated!
Old 12-03-2008, 10:42 PM
Jay351's Avatar
1uzfe! Not many people have done it around here, requires alot of work.
If you're not up to it, do a 3.4L
Old 12-03-2008, 10:57 PM
netgodsrdn2's Avatar
They are both great motors. Personally I have decided that the Lexus V8 will hopefully ensure that I never want for power when I'm driving mountain passes. Now if I can just get the time to actually put the thing in...
Old 12-04-2008, 07:40 AM
toyminator2000's Avatar
They are actually about the same amount of work. the wiring issues are the same and there are places to get them both done. the lexus v8 you have to be careful where you mount it in the engien bay. Its an extremely tight fit front to back and leaves very little room for a radiator and fan. You also need bigger that stock radiator and fan to keep it cool. The lexus v8 is probablyt about half the price to buy the engine but the other stuff you need balances the cost. The Lexus v8 is an aluminum block and is lighter that the 3.4
Old 12-04-2008, 08:31 AM
RobD's Avatar
If you want cool and unique, Lexus V8.
If you want an easier install, 3.4.
I looked at both and ended up doing the 3.4 since it was almost drop-in with its simplicity. Very little in the way of fab work and you can re-use a bunch of your stock 3.0 gear with it (radiator, oil pan, etc.) where the 4.0 needs to have a bunch of stuff fabbed (motor mounts, exhaust, etc.)
Old 12-04-2008, 09:00 AM
mt_goat's Avatar
I vote for the 3.4.
Old 12-04-2008, 10:01 AM
TNRabbit's Avatar
My God; how many times is this topic going to be beat the h@ll to death??!?
Old 12-04-2008, 10:04 AM
SWPERIC's Avatar
has anyone ever put in a tundra v-8? *never searched this one just curious*
Old 12-04-2008, 10:08 AM
TNRabbit's Avatar
USE THE SEARCH; THERE ARE A HUNDRED THREADS ON THIS TOPIC...
Old 12-04-2008, 10:23 AM
tc
tc's Avatar
What are you swapping it into?
The 3.4L is a more straightforward swap - almost everything bolts in to the same holes, just wiring has to be adapted.
The V8 is more work, but the better motor. As noted above, it's actually lighter than the V6 due to the aluminum block. Since the block and the heads are the same material, headgasket issues are practically non-existent. Unfortunately, I don't think anything will bolt in - you'll have to make and locate on the frame motor mounts and have a bellhousing adapter.
... and I spend A LOT of time on here and don't recall seeing a thread like this, so not sure what the "search newb" police are all excited about.
Old 12-04-2008, 10:33 AM
waskillywabbit's Avatar
Just what are you trying to say?
Country Boy, you need to learn to use the "search" function and quit asking your redundantly redundant questions that you have obviously not bothered to look for an answer for on your own cause folks will tire of your laziness quickly.
Old 12-04-2008, 10:53 AM
truckguy001's Avatar
personally, i plan on doing the 3.4 in my truck considering the easy install. after that, i'll through on the TRD turbo. when i looked it up, it says it gives it roughly 350 hp
Old 12-04-2008, 11:29 AM
i meant trd supercharger, not turbo. sorry
Old 12-04-2008, 11:31 AM
jason191918's Avatar
In the bottom right it says "edit." Click that to prevent looking like a fool in the future.
Old 12-04-2008, 11:33 AM
yotasavg's Avatar
oops...my bad..edited
Old 12-04-2008, 06:04 PM
waskillywabbit and jason191918 if it bothers you so bad go to a different thread .............
Old 12-04-2008, 06:14 PM
Talking
Friendly advice. I gave you the link and even posted the words cause I know you wouldn't bother to search for it.
https://www.yotatech.com/rules/updated/index3.htm
15. Searching (or a blatant lack of)
While you will not find a nicer, more helpful bunch than the YotaTech membership, anyone can grow frustrated seeing new threads with the same questions over and over.
A few well spent minutes educating yourself so you ask INTELLIGENT and INFORMED questions will gather much more attention from the seasoned members in the know than a lazy attempt to have the members spoon feed you information.
It is ALWAYS better to add on to an existing thread (if the information is pertinent) than to start another with the same information.
This makes it easier for the next person with fewer threads to pour over to gather their information.
More info on how to search can be found in our newbie section.
A word of warning. If you are a chronic "non-searcher" or if you feel the need to mouth off to either the membership or staff for telling you to search, your stay here will be short-lived.
Old 12-04-2008, 06:15 PM
iamsuperbleeder's Avatar
I smell a forum fight...
anyone else catch a whiff of that
nicely put Wabbit
btw, I love my new shackles!
Old 12-04-2008, 06:17 PM
Glad you like them!
Old 12-04-2008, 06:33 PM
Sponsor
Tofer's Avatar
What the largest size tires can i run on my 81 2wd without rubbing or cutting? i'm sure i can get 27x9.5 swamper SSRs but i'd like to bump that up to 29 or 30
Quick Reply: 3.4 swap or lexus v8
