3.0 crank pulley problem help plz
Old 09-21-2009, 09:51 PM
motorhead2u's Avatar
1988 toyota pickup has 3.0 took the crank shaft pully with power steering keeps spinnng 2nd time there in no key way in the shaft only one way i see is that to take a larger key and grind it down to fit in the smaller key way in the timing belt gear but there has got to be an easy way other than welding it which is my fall back plz any input is most appriciated thank you
Old 09-21-2009, 10:08 PM
Staff
DeathCougar's Avatar
First, start over and explain that in a way that we can understand.
I read it 4 times, and still cannot understand what you are trying to say.
Don't weld anything, its designed to go together a certain way for a reason.
Old 09-22-2009, 08:06 AM
Dalriaden's Avatar
There is a slot for a woodruff key on the crankshaft pulley. Its hard to
Spot because it is where the shaft comes out of the motor.
Old 09-22-2009, 08:15 AM
24Runna's Avatar
Okay, use punctuation and complete sentences, so we can understand.
From what you are saying I'm guessing someone didn't torque the crank pulley down and it wore off the the key way in the shaft? is this correct?
Old 09-22-2009, 08:27 AM
rummerd's Avatar
This happened to me several years ago. The previous owner of my 94 PU with the 3.0 beat the balancer/pulley on with a hammer and did not have it lined up properly. This created a tiny bit of slop between the keyway on the balancer and the key. Over time the pulley wore the key down until it was worn very evenly and you could just barely make out where the key was at on the crank. I had to look very closely and when I found it I was able to tap tap with a hammer and chisel to coax it out. I did not have to hit it very hard, just tap and it will come out. Inspect the keyway on both the crank and the pulley. I needed a new pulley and key and was back in business.
sandyota
02-04-2021 11:16 AM
tobylab
01-18-2016 07:06 PM
thefishguy77
07-30-2015 10:59 AM
redneck17
07-17-2015 07:44 PM
ZONAYODA
07-13-2015 07:17 PM
Quick Reply: 3.0 crank pulley problem help plz
