Old 02-10-2016, 09:25 AM
How-Tos on this Topic
Last edit by: IB Advertising
    Print Wikipost
    2nd gen 4runners lift guide
    Old 01-30-2012, 12:32 PM
      #561
    DetroitStyle's Avatar
    Originally Posted by drmix
    How much did you end up paying for on the set?
    $115 shipped ($45/ea + $25 shipping)
    Old 03-12-2012, 11:20 PM
      #562
    swimman2867's Avatar
    If I replace my stock springs with the FJ80 coils in the rear, and add the sdori 1.5" bj spacer, will the below components work well? Specifically, will the shocks be long enough?
    2- OME N72F- Nitro Charger Rear Shocks
    2- OME N98 -Nitro Charger Front Shocks
    1- OMESD33 Steering Stabilizer
    1- OME 303003 Torsion Bar Set
    I also plan to add a 4" panhard drop bracket and extended brake lines from marlin.
    Let me know if this sounds good.
    Thanks
    Old 03-16-2012, 08:24 AM
      #563
    MalachiRunner's Avatar
    Did you drop the diff (then needing to drop the sway bar) at all to help the CV angle? www.4crawler.com has some pretty good set ups and info for about everything you need for a ball joint lift.
    Old 03-27-2012, 09:12 PM
      #564
    Grossboy88's Avatar
    I ordered a BJ spacer lift for my runner and coil spacer lift in the rear. It seemed like a good idea at the time. Once I started getting into the lifting part it became much more complicating then previously thought. What kit didnt include but needed: Extended brake lines front and rear. Diff drop. Sway bar drop kit front and rear. Shocks need to be replaced as well. Some cutting needed to be done with the BJ spacers. All in all. It comes to $600 after parts and alignment. Halfway to a 4" pro comp lift. Might as well save.
    Old 03-28-2012, 09:14 AM
      #565
    yotasavg's Avatar
    you'll be happier with all those parts than with a 4" lift...
    On another note, I keep seeing adjustable upper/lower rear links for fj crusiers and newer 4runners... I have been hoping to find a set for our generation but have had no luck. Anyone have any insight? Or I'd love to be convinced that I don't need them....
    Old 03-29-2012, 05:25 PM
      #566
    [QUOTE=yotasavg;51894582]you'll be happier with all those parts than with a 4" lift...
    I would have to agree....check out 4crawler.com if you haven't already. He'll get you set up with everything you need at a very reasonable price.
    I've gone to 4crawler with many questions and he is ALWAYS extremely helpful and informative.
    "Lift as much as you need, but as little as you HAVE to."
    Everybody has a different idea of what they'd like to see with their rigs for sure, but a properly installed BJ lift (unless your personal liking is to go bigger) will be awesome. Although $600 is halfway to a pro-comp lift, it's still $600 that you could put towards other internals and/or externals to continue progressing your 4runner in the direction you want to see it go. I've seen ruff country with 3-4" lift kits for around $600-$700 and have heard good things about the product.
    Although it may be frustrating to try and piece it together, a BJ spacer lift can turn out great if all the pieces are acquired.
    Just something to think about, hope it works out for you and remember...have fun with it!
    Old 04-03-2012, 07:06 AM
      #567
    pitmaster's Avatar
    Originally Posted by SR5
    Example with of 1.5" BJ spacers and 80 Series Land cruiser coils
    80 series land cruiser on 33x12.50
    Hey guys, im new here, I just picked up a 95 t4r, Im interested in this lift, i think it looks good, where can I find the rear coils at? thanks for the help.
    Old 04-03-2012, 07:12 AM
      #568
    MaK92-4RnR's Avatar
    The rear coils are STOCK fzj80/fj80/lx450 coils. you can get them out of any of them.
    the front is ball join spacers.
    Old 04-03-2012, 08:12 AM
      #569
    pitmaster's Avatar
    thanks man, so If i find the coils, and the bj spacers, do i need anything else? What exactly is the panhard drop bracket? I assume i need 0-4" longer shocks? sorry for all the questions.
    I have lifted fords, chevys, jeeps, and a tacoma, never a 4runner...
    Old 04-15-2012, 02:55 AM
      #570
    Oldscooltoys's Avatar
    Tryna figure out where I can find these ball joint spacers for a good price for a 94 4runner also what exactly should I look for if I'm lookin for these land cruiser springs? What year and all? Anyone able to give me some advice?
    Old 04-15-2012, 10:37 PM
      #571
    willberforce's Avatar
    what exactly can i use for my differential vents to mount them higher
    Old 04-16-2012, 06:52 PM
      #572
    Luvmeye22re's Avatar
    Originally Posted by six_stringer
    Here's Mine
    93 Runner with 4.5 inch lift on 33's
    I know this is going to sound really random and I might be really far off but were these pics taken anywhere near Pagosa Springs?
    Old 04-16-2012, 08:49 PM
      #573
    This guy has his stuff together, I'd take a gander over this post https://www.yotatech.com/forums/f116...ension-219381/
    Not to post whore either, but on a few of my older vehicles (1st gen pickup and a couple 1st gen 4Runners) I used two front toyota flexible brake lines coupled together (male and female ends conveniently enough) to make an extended rear brake line. I bought them at NAPA on the cheap, compared the price to stainless and saving gas money or shipping made it worth it. Never had a problem. I won't be able to say for sure that this will work on a 2nd gen 4Runner but I am quite sure it would Somebody please correct me if I'm wrong. I did it on an 84 4Runner and a 1980 toy.
    Old 05-10-2012, 03:31 PM
      #574
    MaK92-4RnR's Avatar
    Figured I could add my .02 to this thread now.
    This is EVERYTHING you need to lift a 2nd gen 4Runner.
    1.5" BJ spacers
    FJ80 Coils
    Trailgear Brake Line
    Skyjacker front shocks -SKYH7054
    Skyjacker Rear Shocks - SKYH7024
    4Crawler 4" Panhard
    4Crawler 4" LSPV
    Total cost:
    ~$250 including the 35 dollar rebate on the shocks and the 20% on sale.
    Hope this helps... pictures will be posted when the lift is done.
    Old 05-10-2012, 04:40 PM
      #575
    pitmaster's Avatar
    thanks for the info, im ready to order, i just need the Fj80 coils now, not havin much luck finding them!
    Old 05-10-2012, 04:45 PM
      #576
    MaK92-4RnR's Avatar
    I have an extra set for sale. PM me for more info
    Old 05-10-2012, 04:56 PM
      #577
    pitmaster's Avatar
    Who was the supplier to get the discounts?
    "$250 including the 35 dollar rebate on the shocks and the 20% on sale."
    Old 05-10-2012, 05:00 PM
      #578
    MaK92-4RnR's Avatar
    4wheelparts.com is having a sale on JUST the shocks.
    This link should take you to the Skyjacker shock list:
    http://www.4wheelparts.com/Lift-Kits...el=4RUNNER+SR5
    Old 05-11-2012, 08:57 AM
      #579
    Vantage's Avatar
    1.5" BJ spacers
    FJ80 Coils
    4Crawler 4" Panhard
    4Crawler 4" LSPV
    Total cost:
    MaK92,
    Have you installed the Skyjacker shocks yet? If so how do they ride? Anyone else that is running them please chime in.
    I am likely purchasing a 92 this weekend and I am looking for a super cheap lift for the truck. The truck will only be a weekend camping warrior and winter beater so I want to keep prices down.
    I would like to keep my lift low, 1" front and OME medium's rear and run 32x11.5's.
    Forgive my lack of knowledge on the 2nd gen's, I only know about IFS taco's and 4Runners. Are the panhard and LSVP needed for a mild lift like I am planning?
    Thanks,
    Old 05-11-2012, 09:21 AM
      #580
    MaK92-4RnR's Avatar
    Originally Posted by Vantage
    MaK92,
    Thanks,
    If you're thinking of doing just a 1" lift... I'd either:
    Front:
    A. Crank the Torsion bars 1", buy some new shocks
    B. BJ spacers, relax the torsion bars, buy some new shocks.
    Rear:
    A. 4Crawler 2" rear coil spacer
    I haven't installed them yet, and they probably wont be installed until Saturday or Sunday. Anything will be better than the shocks i have on there now... Les Schwab Specials - they have close to 70k miles on them of wheeling, daily driving, and smashing the dunes at pismo.
    Quick Reply: 2nd gen 4runners lift guide
