22re wont start its trying but just wont? help
ok i have an 85 4runner i already started a thread about it but no ore response heres the link look at it please https://www.yotatech.com/forums/f116...e-help-201155/....
ok and i the timming is been checked like 10 times its getting gas its getting great spark.....to every wire.... when i crank it over and dosent start i pull a plug out and its wet with gas so i know its getting fuel..... stil dosent start up i mean its acts like it wants too but just never does?
If you truck has a solenoid resistor and it goes bad your truck won`t start. I had the same problem with my 86 4Runner. I had good spark and fuel but it just wouldn`t start, i checked everything i could think of and still nothing, i had a spare solenoid resistor and just for the heck of it i decided to try it, and to my suprise it started on the first try. So see if you have one on your truck and check it out.
ok i have an 85 4runner i already started a thread about it but no ore response heres the link look at it please https://www.yotatech.com/forums/f116...lp-201155/....
9.8 volt drop is alot. normally should only be 1v or so drop.
have you tapped the starter? tap it a couple of times with a ratchet or wrench. unhook your battery first to prevent a slip.
Check your grounds, do continuity checks between the frame and your connection point.
Im not suprised, its not a common part thats normally replaced, so you would need to look in a wrecking yard or go to the dealer. When mine went bad i found one at pic n pull. In your case, go to pic n pull on Sunrise Blvd, I go there alot, you should be able to find one there. (pocket part). Grab an extra one for a spare.
I live in San Pablo, a little over an hour from you. Im up there at pic n pull about every other weekend, and also because my 4Runner is at my cousins house by placerville, so i go up there to work in it.
