22RE startup issue
Old 11-26-2011, 08:48 PM
summit4runner's Avatar
22RE startup issue
I have a 1988 22RE and I'm trying to figure this out.
The first time I start it for the day, especially when cold, the check engine light will come on and it will kinda sputter like the timings off or something.
If I feather the gas a little for about 5 seconds, the light goes off and it runs fine.
If I turn the key to ACC first and pump the gas pedal 5-6 times and then start it, it is normal, no sputtering.
After I drive it for a couple minutes I can turn it off and start with no issues whatsoever.
Other than that, it drives great, MPG is normal, no other issues.
Any ideas?
Old 11-26-2011, 10:17 PM
Inferno451's Avatar
Got the same problem intermittently with my 87'. However, pumping the pedal and turning to ACC shouldn't do anything on a fuel injected engine. The fuel pump doesnt turn on until the engine is actually spinning. I've always noticed that when mine is hard to start it helps to give it a little throttle too.
Old 11-27-2011, 09:10 AM
I'm hoping this isn't something serious damaging the motor when this happens. I have no idea why pumping the pedal help, but it does, or maybe its just that the pedal is pressed slightly as I start it.
Old 11-27-2011, 09:21 AM
old fart's Avatar
Sounds a little like my 4 runner, the shop mechanics i used to work with have told me it's the EGR valve, but i have yet to hook it to a diagnostic scanner yet to verify it.
Old 11-27-2011, 12:24 PM
jeetS's Avatar
what codes does it throw?
Old 11-28-2011, 01:29 PM
91muddog's Avatar
cold start injector?
Old 11-29-2011, 11:01 AM
I just checked the resistance on the cold start injector. With neg. battery d/c'd and the meter set at 2000 I get 99 or 100 between the 2 terminals.
Can anyone tell me what that means?
Old 11-30-2011, 12:39 AM
91muddog's Avatar
Resistance should be 2-4 Ohms.
Old 12-04-2011, 06:54 AM
89tonkatoy's Avatar
x2 on the csi had one that would work and not changed it out and starts eveytime
MO transplant
04-23-2023 11:58 AM
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
PlayAwhile
07-20-2015 11:36 AM
rushw
07-18-2015 01:46 PM
Quick Reply: 22RE startup issue
