22RE Smoking Black Smoke.. NEED HELP PLZ...
Well i have a 94 toyota... that i bought a brand new shinny in a box engine from japan moters.. and i have about 800 miles on it and it Smokes bad when im driven mostly up hills on dirt roads. (i think its cause the engine is working harder on the soft roads) The truck will start smoking like a frait train. ( or if u ever seen a nascar car blow up) but it smokes for like 30 sec's then it clears up... beteen my self and a couple close friends weve had probably 50 toyota 22r pick up... and NEVER seen one do this.. and i also took out all the plugs thinking it was a ring problem... but if it was it would have to be the back 2 cylinders cause the plugs were both oiley... so im thinking it maybe the PVC problem.. as it dumps into the intake between the 2 cylinders.. but i to bought a advance PVC and its probably no good as i read some wheres else. what would be causen excess pressure in the case? and has anybody else had this kind of problem??
steve miller
10-10-2015 01:40 AM
