22re Runs Terrible
22re Runs Terrible
Yesterday I replaced the AFM on my 22re because it would go erratic under a load or at high RPM, well when i replaced it it did the same thing, but worse it also has no power what so ever
Anyways.
Start with voltage checks, ideal is 12+ volts a minimum of 10 at the battery, the ECU and VAFM. VCC at the ECU should be dead on 5v, and little if any variation at the VAFM(VC) and TPS(VC or VCC).
VAFM and TPS should have smooth curves closed to open on Vs and Vta.
