22re idle surging with A/C on
Old 08-30-2009, 08:39 AM
93YotaMonster's Avatar
ok guys im still having trouble with my truck, i have a new problem wen i turn the ac on the idle starts to surge. the truck has a new IAC,cap,rotor button, spark plugs, and plug wires. the truck is a 93 22re 4wd mods are in my sig minus the MSD coil and accel plug wires
Old 08-30-2009, 08:53 AM
abecedarian's Avatar
check for vacuum leaks. also that the a/c idle up adjustment isn't too high or low.
Old 08-30-2009, 09:35 AM
how do i check the A/C idle up?
Old 08-30-2009, 09:45 AM
on the side of the intake manifold is the a/c idle up valve- has what looks like a big screw on it:
With the a/c off, it does little to nothing, but when the a/c's on, it allows some air to bypass the throttle and raise the idle speed. Turn the screw in with the a/c on and the idle should lower and vice-versa.
Old 08-30-2009, 09:51 AM
ok ile give it a try. thanks abe
smthwsn357
12-04-2023 02:08 AM
MO transplant
04-23-2023 11:58 AM
montanatruck
02-26-2017 07:07 AM
jackiebrownia
07-20-2015 09:02 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 22re idle surging with A/C on
