22re Factory Air cleaner housing Differences?
Old 02-17-2011, 03:46 PM
DanStew's Avatar
I got my 86 4runner and the PO took off the pair vavle plumbing. I was able to get the plumbing from the junkyard to reconnect the valve and get the engine back to factory. Well I go to connect the hose to the air filter housing and..... there is no connection available. I check how it is on my 89 22re and the hose connects to the upper half of the air cleaner housing. I go and recheck the 86, and there is still nothing that even remotely looked like there was a connection.
My question is, does the 22re use differnt configurations of air filter housings? I am assuming somewhere the unit was changed, either the top was chagned out, or the bottom. I would like to know the changeover years so i can search for a new housing or try to weld on a fitting to attach the hose.
Thanks
Old 02-17-2011, 03:51 PM
sebastianholmes's Avatar
why do you want all that crap back? just makes it more complicated and clutters the engine bay?
Regency
20
01-03-2020 07:43 PM
andrewtexas123
07-14-2015 04:29 AM
msane99
07-11-2015 08:08 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: 22re Factory Air cleaner housing Differences?
