22re Exhaust Flange?
Does anyone know if this drawing is correct or have a dwg or dxf file I can have?
http://www.gatechlocost.com/wordpres...ust-flange.jpg
Thanks,
-Jarrod
Thanks,
-Jarrod
need dxf file for laser so I can see what a turbo looks like next to that supa fly flange
Unless I pull mine apart, I don't have anything to measure against and I need to have these cut asap while the getting is good
Thanks in advance
Thanks in advance
uhh..that doesn't look like it'd bolt up to the head of my 22R (same head as 22RE)
the bolt holes on the bottom closest to the inside are too low i believe.
mine are level all the way across
Yea I see what you are saying. Some of the dimensions look a little funny.....and I am sure it was designed with metric measurements from toyota so the drawing dims may be off some.
Nevermind...it's right...I will have to register on pirate to thank the guy.
http://www.pirate4x4.com/forum/showthread.php?t=777197
