22re engine hunts
Old 04-15-2009, 03:36 PM
Ride On's Avatar
Question 22re engine hunts
I have a 94 Toyota truck with a 22re engine and the idle hunts anybody know what causes this? it's not the tps
Old 04-15-2009, 04:22 PM
Flash319's Avatar
Idle is to high. Once your idle-E2 contact is closed on the TPS and the engine is up to temp your idle can not go above about 1100 or it will start doing that. This can be caused by a vacuum leak or improper idle screw setting.
Old 04-15-2009, 07:30 PM
Ride On's Avatar
thanks man
Old 12-15-2017, 03:16 PM
Kent2's Avatar
Engine runs great until I turn on heater blower to HIGH. Then the engine "hunts". It acts like the tranny is shifting in and out of OD.
Old 12-15-2017, 03:54 PM
RAD4Runner's Avatar
Kent2,
As mentioned about idle above.
I had similar problem when AC is on and I stop at ramp from freeway speed. Got fixed when I adjusted idle to spec.
Old 12-15-2017, 04:43 PM
Thommo Thompson's Avatar
yes its usually related to a vacuum leak or fuel pressure regulator, and coincidently, its often a vacuum leak at the pressure regulator vacuum hose!
Colington
03-08-2020 09:51 AM
Doug4320
03-24-2018 10:11 PM
steve miller
10-10-2015 01:40 AM
crashburnoveride
08-28-2015 09:20 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 22re engine hunts
