22RE Coolant Lines/Hoses
It is time to replace my radiator hoses on the 22RE and I would like to replace every line that holds coolant for the motor. Better safe than sorry. I would like to order all my hoses at once and do a flush and fill with Toyota Red coolant. Is there a list of all coolant hoses with toyota part numbers somewhere?
1990 Toyota Pickup DLX Regular Cab
22RE
5 speed
22RE
5 speed
3 lines coming off the pipe coming off the back of the Timing cover on the pass. side. 2 coming off the IACV. 2 Radiator hoses. 1 coming off the bottom/front of the intake to Throttle body.... 2 for heater core(mine is 3 due to a bleeding/flush gate, which I recommend). 1 In the middle of the intake manifold that wraps around the back(the rubber portion is at the end of that pipe... I believe it's one of those that go to the heater core). The other heater core hose IIRC comes from the pipe coming out of the driver side pipe-to-rear of timing cover piece. There is one curly one that comes up and around the thermostat housing, think it comes from one of those under the intake/or back of the timing cover on pass. side. I got that and more from the dealer, as they're specially tapered and angled to fit perfectly without any possibility of kinks, etc.>>>>>
Toyota Dealership will have a diagram with part numbers for every hose. You could get it much cheaper from www.toyotapartszone.com or something like that, I would think. I call www.dealerdirectparts.com and speak with them, give them the vin, then they make sure I get all the ones I need.
Best wishes.
Best wishes.
the1998sr5
15
07-14-2020 08:35 PM
Tacoma1313
08-17-2015 05:44 PM
itzmywife's
07-25-2015 04:55 PM
