22R Vacuum Advance
Old 10-25-2012, 10:57 PM
stevewaclo's Avatar
22R Vacuum Advance
Hello all,
I may be the last one on this end of the galaxy to find out, but LCE Performance has an excellent price on vacuum advance devices for 22R Pick-ups. As many probably know, dealer cost is north of $200 and other Internet sources are in the low $100's.
Discovered mine was defective when I tried to pull a vacuum and found both diaphragms to be leaky. One caution on the replacement unit. Although it is a simple R&R (watch out for the small retainer clip that holds the VAD arm to the movable distributor plate) the arm is not quite the same length as OEM and you'll be wanting to get out your timing light for final adjustment. Also, my distributor plate was binding so take a look at that as well. A bit of oil and back in business.
Best wishes.
Old 10-26-2012, 08:22 PM
ilovelivinginthecity's Avatar
Thanks for the heads up.
How do you go about testing the vacuum on the diaphragms?
Old 10-26-2012, 09:07 PM
TrikeKid's Avatar
Vacuum pump, you should be able to advance the dist and it should hold that vacuum once you create it.
icentropy
09-16-2020 02:47 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Sr5crawler
07-31-2015 12:32 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: 22R Vacuum Advance
