22R timing issue
Old 07-27-2010, 02:03 PM
Travisfab's Avatar
22R timing issue
I am trying to time my little stock 87 work truck. It's your basic carb'd 22R.
The setting I need to get to is 0 degrees with the distributor vacuum lines pulled.
The distributor bottoms out at about 5 degrees, I cant bring it down any lower.
I am just not a motor guy, I'm guessing there is something on the carb I need to adjust, I'm just not sure what?
Old 07-27-2010, 02:20 PM
xxxtreme22r's Avatar
the carb has nothing to do with the timing. wait, wait wait, yur joking right travis? almost had me fooled there for a second. lol
Old 07-27-2010, 02:29 PM
Travisfab's Avatar
I can install a motor, but tuning it is like speaking French to me. Could my distributor be off a tooth?
Old 07-27-2010, 02:54 PM
Travisfab's Avatar
edit, bottoms out at 8
Old 07-27-2010, 03:17 PM
yeah could be off a tooth.
Old 07-27-2010, 03:18 PM
to put a reference on it 0 degrees on mine is almost exactly halfway on the adjusting bolt in the bracket if that makes sense to you.
Old 07-27-2010, 06:17 PM
mikes451's Avatar
You need to plug the vacuum lines after you pull them.
Old 07-27-2010, 07:05 PM
Travisfab's Avatar
I am plugging the lines when I check, I pulled and re-indexed the distributor about 10 times, it either runs or it doesn't, and when it does run the timing just will not come down.
Such a pain. the truck runs like a champ too!
Old 07-28-2010, 04:36 AM
maybe the springs (mechanical advance) in the distributor are wore out? are you running an OEM unit or a DUI? I am guess OEM since you said it's your work truck and not the prerunner.
Old 07-28-2010, 04:39 AM
travis when you pull the dizzy you have to make 100 % sure your at TDC on the compression stroke not just TDC. By TDC compression I mean the mark on the balancer has to be at 0 AND the #1 exhaust and intake valve rockers MUST be loose. (not loose by un-tightening them)
Old 07-28-2010, 04:41 AM
also are you certain the timing chain is also correctly lined up? as that will also affect the dizzy, contrary to some people's belief.
Old 07-28-2010, 10:45 AM
Travisfab's Avatar
I have no idea on the timing chain. The truck had just had a new head installed before i got it. The distributor is stock too.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 22R timing issue
