1995 4 Runner with low speed sputter
Bought a 1995 4Runner with a 3.slow in it a few months ago for beach use and sometimes as a ride to work. Had alot of codes when I bought it so I replaced :Timing belt and all tensioners, upper and lower intake gaskets, knock sensor and wire, serviced injectors, cap,rotor,plugs,wires,tps,cleaned egr throttle body and all parts of the manifolds,replaced vacuum modulator,set timing. The problem is when i drive it at a low speed for around 1 minute it sputters as if its loading up . This condition lasts around 10-20 seconds then goes away. Pulled plugs they look fine. Any help is appreciated Thanks in advance
