1994 pickup 4x4 frame replacement question
Hi guys, my 94 pickup 4x4 manual SWB regular cab's frame is messed up bad. I need to replace the frame but checking out my local junkyards in las vegas recently turned up nothing for me. There is a lot of 4runners in the local junkyards but just not sure what frames are interchangeable with my pickup. Can anyone tell me which vehicle models are an exact match to my pickup if any? Any help would be great. Thanks in advance.
4runners are different frames. Front section is similar but the back is different due to the body mounts and read coil spring suspension. You are closer by going back a model to the 86-87 frame. Other then that you will have to find a 89-95 reg cab frame.
FS[FourCorners]: 1992 Pickup 4X4 Manual - SLC, Utah
HappyAdventure
02-20-2016 06:32 PM
BarefootGeologist
02-15-2016 06:01 AM
