1992 4Runner - Rusted Rear Brake Line.
How do I get at it?
I'm assuming I need to drop the gas tank (UGH!)
How hard is dropping the gas tank?
The leak is in the TOP hose/line in the 2nd picture
Anyone else have a rusted brake line in this spot?
I've never replaced a brake line before.
Tips to make this job easier will be greatly appreciated!
THANKS!!!
THANKS!!!
THat looks pretty bad.
If you need any parts I may have them I have a 1990 i am parting out here in caloifonia. Here is some of the stuff from the barkes I have removed.
parking brake cables
Yeah, that's what I did. I just bought a roll (25') of coated brake line (lasts much longer than regular steel lines for just a bit more money), and pushed it in between the frame and gas tank. I put connectors on, flared the ends, and bent the line so that it ran pretty much the same path as the old line.
Cut the lines wherever it is convenient. On my truck the brake lines are accessible along the frame under the passenger door. There were two on mine and I just did both. Cut and run them back to the LSPV.
The two red lines are brake lines and the blue one is your fuel line if I remember correctly (don't cut that one).
I wouldn't splice in your brake line at all. If it's rusted through, chances are you'll have a hard time flaring that old tube anywhere along it's length (... and be able to get a good seal). I would remove that whole section of line. It goes from the LSPV to the front of the truck. Depending on which of the two lines it is, it either goes to a threaded fitting (T or union... can't remember) behind your front passenger wheel near the frame, or it goes way up front to your ABS module (under your battery). Just cut the line where it's leaking, then remove it totally. You should be able to trace it as it goes above the gas tank with your hands (have a buddy handy to help you out. One guy can move the tube at one end of the tank, while the other guy checks which tube is moving at the other end). Once the old one is removed, just route the new line where it's convenient, put the connectors on the tube, and flare the ends.
I'm having basically the same issue as described here
Though I'm curious what the size of connectors I will need to screw onto the existing connectors
Unless you live in the Sun belt and the truck never sees water.
You always want to replace brake lines threaded connection to threaded connection.
I have never been able to make a double flare on old steel line they always crack.
another tip that works make your flares after putting on the nuts away from the vehicle. where you have room to work.
when you push the line past the fuel tank Or any where it could get dirt in I just use electrical tape to cover the end. When ready to connect just remove tape.
Flash319 used to have a good connection for these brake line nuts at a good price
Aleeex_u
06-05-2016 06:52 PM
voiddweller
19
05-02-2016 09:10 PM
cchinny
06-25-2015 08:11 PM
dirtrider0129
10
06-24-2015 12:24 PM
JaredL
06-16-2015 04:47 PM
