1990 4runner chop and bob.
Old 03-03-2008, 06:56 PM
  #41
run4her's Avatar
Trail-gear sas swap purcased woohoo. Now i have to finish and do that lol. I dident cut my top like theirs because i wanted the window more streight up and down. Iam going to do the removable glass.
Old 03-03-2008, 06:57 PM
  #42
Elvota's Avatar
Originally Posted by Chrisnxl185
It couldn't be any heavier than the 1st gen removable tops right?
Well... the 1st Gen are fiberglass, and designed to be handled. I think you'd find the 2nd and 3rd Gen tops to be substantially heavier.
Not that it can't be done. Maybe some sort of hoist system you park under?
Old 03-03-2008, 07:19 PM
  #43
run4her's Avatar
Who on here has done the sas swap. How hard is it?
Old 03-03-2008, 07:25 PM
  #44
Elvota's Avatar
I am sure you have seen this section... but just in case:
https://www.yotatech.com/forums/f152/
I did a SAS. Maybe a bit harder than your current project, but mostly because all the metal you are going to be cutting through is thicker and can be harder to get to.
I did it all with a grinder and SawZall. If you have a torch or plasma your life will be much easier.
Most difficult part can be making the rear shackle holes through the frame. There is internal webbing that makes for 3 walls you have to get through. Can be a pain.
Old 03-03-2008, 09:03 PM
  #45
fillsrunner4's Avatar
very hard
Old 03-03-2008, 09:18 PM
  #46
Sponsor
Tofer's Avatar
Originally Posted by fillsrunner4
very hard
x2..... leave it to professionals or a drunk group of buddys....
Old 03-03-2008, 10:26 PM
  #47
YeloSub7's Avatar
looks sweet dude, keep us updated!
Old 03-04-2008, 12:57 AM
  #48
run4her's Avatar
Aww it cant be harder than chopping and bobbing because welding sheet metal sucks.
Old 03-04-2008, 11:09 AM
  #49
If you could chop and bob the rear you should have no troubles with a SAS its truely very easy and after I did mine I bet it would take me a day Maybe two to do it again
Old 03-04-2008, 04:05 PM
  #50
run4her's Avatar
Well im off to work on it some more.
Old 03-04-2008, 04:12 PM
  #51
312necro213's Avatar
Don't forget to take pictures please, I am Very interested in this I am looking at the full assembly for a taco rear window as we speak. I want to build a full wall in the back and then redo the interior so it all matches.
Old 03-05-2008, 02:07 AM
  #52
run4her's Avatar
I just got home and its 3:06 Am i completed the window and some welding. All in all it is tons of work but it was very gratifying to drive it and it was quieter inside than ever with a thrown up sheet metal wall LOL. I will post pics in the morning.
Old 03-05-2008, 09:14 AM
  #53
run4her's Avatar
Here are some more pics.
Now for the rest of the body work, side panels, bed caps, and paint.
Old 03-05-2008, 09:51 AM
  #54
Elvota's Avatar
Looks like it's coming along. Must be nice to be getting things back together.
In regards to this gap:
Do you think this could be avoided if you cut the back differently, or is there just two much of a height difference between the very back of the cab and just behind the rear doors.
When I chop mine, I am trying to figure out where to cut so I'll have a chance splicing it back together. I may end up just moving the original window as you did. Looks good.
Old 03-05-2008, 09:56 AM
  #55
run4her's Avatar
I think when i put in the bed caps i got of a 3d gen pickup it should mesh into that gap smooth. I dont know if u could avoid it but it would be worth a try. If i could do it again i would have thought it all out before i started cutting. LOL
Old 03-05-2008, 10:00 AM
  #56
Elvota's Avatar
Oh yeah... think before cutting. I'll have to add that to the top of my notepad.
The 3rd gen cap idea is a good one. Should clean up the edge nicely and fill the gap. Are you bed sides really flimsy right now? If you removed the tailgate, would they fold in easy pushed against a rock?
What machine are you using to weld all this back together? Will you bondo to smooth it all out and then paint... or just leave as is and fill with mud from the trail?
Old 03-05-2008, 10:52 AM
  #57
run4her's Avatar
The bed sides are super flimsy. I will be filling it with bondo then painting it and i may print out some cool graphic on vinyl for it. I own a vinyl graphic shop so that helps lol.
Old 03-05-2008, 05:47 PM
  #58
run4her's Avatar
does anyone have anymore ideas on how to make anything better?
Old 03-30-2008, 08:33 PM
  #59
MossyRocks's Avatar
I told myself Id never post here but I guess Ill give some insight.
The top without the hatch is very light, I would guess about 1/4 of what a 1st gen top weighs. Yes I did drop it off the forklift but I did fix it. I honestly just didnt feel like messing with it anymore so it got a window in the back. Its polycarbonate and fully sealed, takes about a minute to pull and lay behind the seat.
I was gonna give the roll down glass a try but the coilovers are going there along with the air compressor and now the fuel cell.
Here she is as of now.
  #60
MossyRocks's Avatar
And good luck in your endevour.
Quick Reply: 1990 4runner chop and bob.
