1986 Pickup - Need to remove and plug Rear Brake Lines, Need help...
Old 11-04-2015, 11:38 AM
vinman33's Avatar
Hey Guys,
I have and 86 Toyota pickup 4x4 sr5 XtraCab with @ 250K. She runs fine but the rear brake line rusted thru right behind the gas tank and after taking a look at under the truck the frame is severly rusted and is not safe to drive on the street IMHO, plus the inspection is past due so I would like to just use this as my farm/yard motorized wheelbarrow.
Question is how can I remove/disconnect the rear lines from the master cylinder and block the hole from the removal of the rear line? Do they sell special bolts or brake part kits for this? or do you guys have any innovative ideas?
Thanks
Vinny in PA
Old 11-04-2015, 12:17 PM
wyoming9's Avatar
Red face
In the past I have taken a flare nut with a short piece of line and silver soldered it closed.
You need the line so it seals
Then just bolt it into the rear brake port of the master cylinder.
Tig welding works as well
I am sure if you look you could find a plug that works
I never really took the time when I needed it I could not wait.
Old 11-04-2015, 12:20 PM
vinman33's Avatar
Thanks - Ill take a look at my nuts/bolts parts jar to see what will fit!
Old 11-04-2015, 11:53 PM
wyoming9's Avatar
Red face
It would be a flare nut and brake line that fits your truck!!!
old87yota
09-09-2015 12:39 PM
Squigglez
09-04-2015 07:33 AM
I8URSVT
09-03-2015 11:42 AM
Aaron Logan
09-03-2015 08:08 AM
94yota212
09-01-2015 08:01 AM
Quick Reply: 1986 Pickup - Need to remove and plug Rear Brake Lines, Need help...
