1986 22r carb
Old 07-12-2010, 01:45 PM
blazer eagle's Avatar
1986 22r carb
my friends truck is having problems with the float - should he rebuild the carb? meaning how difficult is it? or should he go with a new carb such as a weber or something? who makes carbs for these motors?
thanks
Old 07-12-2010, 01:52 PM
myyota's Avatar
Junk the stock carb if possible and get a weber, its a better carb, it will give you a little more power and better gas mileage once you get it dialed in.
Old 07-12-2010, 02:01 PM
ok, which weber carb am i looking at and where is a good place to buy them?
Old 07-12-2010, 02:14 PM
xxxtreme22r's Avatar
www.webercarbsdirect.com 32/36
Old 07-12-2010, 02:26 PM
swampfox's Avatar
you can buy individual parts for the stock carb or a kit ,they are good carbs.it is cheaper to rebuild than to replace.
Old 07-12-2010, 02:45 PM
how hard are they to rebuild? ive rebuilt little two stroke motors and carbs but they arent too complicated
Old 07-12-2010, 03:10 PM
swampfox's Avatar
they are not bad to rebuild. just take you time and lay the parts you remove in a out in some order. clean it up good and if you use carb cleaner to spray out the passages wear safety glasses. because if you spray into a passage on one side ,it will come out were you least expect it and straight into your eyes.
Old 07-12-2010, 04:41 PM
whorider's Avatar
Don't put a weber on. The stock carb does a much better job of altitude compensation. Plus the rebuild kit is only around $60. They aren't that hard to rebuild. My advice is steal/borrow the wife/girlfriends muffin tin. Each section that you take off the carb put it in a different muffin pocket. When you go back together you know you will put it together in the right order. Plus, every part only has one home. Heck have your buddy take pictures while tearing down. The hardest part I think is the linkage on the back.
Also you can do just the float with the carb on the truck.
Old 07-12-2010, 04:43 PM
whorider's Avatar
Explain "problems with the float". Set wrong? Sticking/hanging up?
highonpottery
11-22-2015 03:57 PM
tyman91
09-17-2015 11:04 PM
bhaithc
09-17-2015 07:53 PM
skouba
09-14-2015 06:58 AM
Gurr
09-12-2015 09:51 PM
Quick Reply: 1986 22r carb
