Problem with pro comp drop drag link
Old 11-07-2015, 05:25 PM
jhsantacruz63's Avatar
Hello, I just recently purchased a 1985 Toyota pickup but am having an issue with the steering. When I got it the steering was very sloppy. I found that the stock drag link was shot. I got a pro comp drop drag link since the truck has a 4 inch lift, seemed like a good thing. The issue I'm having is that when I go to install it, I have soft steering one direction and stiff the other. What I have found was that there are the two springs, one in each drag link end, that are supposed to help with bump steering. Well, the way the directions show to put it together, it's causing the arm to compress both springs one direction and neither spring the other direction. This doesn't seem correct to me...
The stock drag link I removed had one spring inboard of the ball on one end and one spring outboard on the other end so that one spring was compressed in either direction. I don't know if I got sent a drag link with a wrong end in it or if I'm doing something wrong. Any help would be greatly appreciated.
Thanks
Old 11-07-2015, 07:33 PM
nvdesertrunner's Avatar
4crawler has a little info on this. He used a different brand drop drag link but he notes it was designed same as yours- compression one way for tight steering, springs engaged other way for loose steering. He just clamped down on the cap screws as tight as possible and says that helped.
Here is the link:
http://www.4crawler.com/4x4/4R_suspension.shtml
Old 11-07-2015, 07:35 PM
Here is the link:
Great thank you, I'll take a look at that.
89hilux1
09-14-2015 06:13 PM
ToyotaMD
09-07-2015 04:44 AM
I8URSVT
09-03-2015 11:42 AM
Aaron Logan
09-03-2015 08:08 AM
Nick Berg
09-03-2015 04:36 AM
Quick Reply: Problem with pro comp drop drag link
