22r running horribly
#41
Good idea, that is what I'll do. I've been looking at pictures everywhere and can't figure anything out.. I will look into if there are different motor mounts for different applications (years/4x4vs2x4)
#42
Yup all I found was some pieces of RTV and a seal spring from a valve seal. Ran a magnet through before cleaning/dumping out oil pan luckily, the oil pump gear wasn't grinding together. There was enough clamping force between oil pump/timing cover to keep that from happening. Was a clean break. The piece that broke off is just a collar/spacer that slides into housing
#43
I just pulled engine mounts off a 86 22re. Driver's side bracket uses a bracket (Power steering I think?) to space out for the offset. Passenger side had two thick washers that appeared to be the same thickness. This is the engine mount bracket to engine block. The engine appears to have been freshly redone, and the engine mounts look pretty clean and not rusted up, just oil covered. If you want I could send them to ya with the brackets etc for fairly cheap if you want to give them a shot. There's no marks on the oil pan that I can see anything rubbing, but this is a 4x4 pickup.
Also have the oil pump drive gear and such, looks like it's all in good shape.
#44
I have some 2wd trucks, but they have all the options so not the greatest for getting photos (ac/power steering). I have a guy buying all my 22re stuff, so I'll be pulling the 87 2wd 22r long box xtra cab engine that I'm thinking of.
Based purely on what I've seen from Toyota, the 2wd vs 4x4 frames are probably different, but the mounts and brackets are probably the same. LIke the front diff for a T100 is the same as a 4runner and pickup, but the cv axles were made longer due to the wider frame. Even the manual lockouts swap on .
#46
Thanks for the pics!! The 2wd motor mounts look identical to mine. It's gotta be something wrong with my steering or suspension
#47
Not a problem. Were you needing the oil pump drive or is there a source for them new? I have the whole oil pump assembly. The engine appeared to have been rebuilt at home by someone that didn't really know what they were doing. They didn't torque things down enough, including the rods, so one came loose and knocked a hole in the side of the block. Head gasket and such looked like new when I pulled it apart.
#48
#50
Is that the right oil pan is a good question. I pulled the engine out of my 2x and put it in my new(to me) 4x4 and I had to change the oil pan. A 4x4 oil pan is a lot deeper then a 2x oil pan.
Here is a link to a 2x oil pan:
https://www.google.com/imgres?imgurl...AgwCA..i&w=250
and a 4x4 oil pan:
https://www.google.com/imgres?imgurl...AEwAQ..i&w=320
I hope this helps,
grey
and a 4x4 oil pan:
I hope this helps,
grey
#51
Here is a thought, I had a problem with my truck, 22R engine out of my 1985 2x Toyota Pickup. I believe it is called the auxiliary accelerator pump. It is a 3 holed diaphragm that goes in the carburetor on the side by the valve cover gasket. If the diaphragm has failed it will flood your engine at idle and not run so good. It is easy to check. Pull the vacuum line to it and if it has gas in it the diaphragm has failed and needs to be replaced. You can replace it without removing the carburator. I did, I pulled one out of the bad engine I got with my 4x4. Price seems high for it at this place but here is a link showing a picture of what it looks like: http://www.partsgeek.com/1lpdvsr-toy...FYFYfgodbjoB3Q
good luck,
grey
good luck,
grey
#52
Based on those google pics, OP has a 2wd oil pan (notice the several grooves). Since we're not going after the mounts, it's possible the drag link got bent. Pretty sure it should be nice and stright/flat, no bow etc. New drag link for my 2wd 86 pickup was around $100, but my oem one had a bad joint on it that someone rigged up with soft rubber. Drove great on clear roads, snowy rows it was all over the place.
For the AARP, the fuel in gas line is a great test. My truck had that, ruff idle and I could tell it was because of running rich. Ended up just cutting a gasket and making a block off for it. Really isn't needed unless you go from idle to floored all the time (racing etc). Another way to "delete" it would be to pull the line and block it off, and put a vacuum line cap on the port on the carb.
Also no prob on the oil pump parts. I read it for what it was, and thought it looked a bit different than what I remembered lol.
#53
and a 4x4 oil pan:
I hope this helps,
grey
and a 4x4 oil pan:
I hope this helps,
grey
#54
good luck,
grey
good luck,
grey
Thanks for the info tho! Currently waiting for new head, gaskets, head bolts, and timing chain set to arrive
#55
I haven't heard any probs with the aftermarket weber carbs, but it could have the same prob as any carb, dirty inside, jets getting plugged etc, never hurts to clean them or "rebuild" as people like to put it with new jets.
No fun with the exhaust valves and the bent valve spring, could be worse though.
The images linked reminded me of the 2wd 95 pickup I pulled the pan for someone, it also had the several grooves and I think it dipped the same way as the pics. Maybe the older engines were slightly different shaped.
I did some googling and didn't come up with any exact matches. Celicas and MR2's had the 22re engine in the past, but the oil pan pics I found of them didn't match. Maybe nothing is wrong and it's just the oil pan, question I'm wondering is what machine did the engine come out of then (assuming it was swapped). When you pull the head, check if it has "domed" pistons or flat top. Flat top should be 84+, domed is 83 and older and the whole front of the engine is ever so slightly taller where nothing interchanges.
#56
http://www.ebay.com/itm/2wd-oil-pan-...AAAOSwbsBXpPxD
http://www.ebay.com/itm/OIL-PAN-20R-...VYPyzV&vxp=mtr
grey
#57
#58
I went and looked at other oil pans and yours looks funny to me. I have both oil pans from my two trucks. And neither one of them looks like your oil pan. From what I'm reading it fits the 20R and 22R engines. Here are links to a couple other 22R oil pans Second one has the best pictures:
grey
grey
#60
Shagool22, should you decide to change your oil pan, it is critical to make sure you have the correct oil pan pickup tube in the oil pan. I learned this when I changed a 2x engine into a 4x4 engine. You likely already knew that, but I would hate to not say it and you or someone reading this fry an engine because they kept an old oil pan pickup tube.
grey
grey
