Smog question for toyota '79 truck valve assy air switch
I'm trying to figure out how these connect for smog check.
I circled the pipes to where they should connect.
Three options for red, yellow, and white:
1. air/smog pump
2. air intake assy
3. some pipe coming from behind the engine
part#: 25710-38030
1. air/smog pump
2. air intake assy
part#: 25710-38030
this is thread on desmogging but i think i remember seeing something about those hose connections in it
https://www.yotatech.com/forums/f114...torial-264405/
I just removed mine which looked very similar on my 78. If I remember correctly I believe it was:
Red- Smog Pump
Yellow- Air Filter
White- Exhaust manifold (tube behind engine)
Red- Smog Pump
Yellow- Air Filter
thanks, im trying to smog, do you think i still need the vacuum piping assembly in order for this part to work?
Not particularly, I'd imagine most of the parts are crazy expensive from the dealer. I'd keep a close eye on the junkyards, maybe find a truck when it first comes in the junkyard and grab all the parts you need
WTB[SouthCent]: Idle Air Control Valve PN:22230-35010 22re
dbbowen
09-23-2016 04:57 PM
FS[FourCorners]: Complete 99 Toyota E-Locker Rear Axle in Denver
jtinco
08-11-2016 08:27 PM
