Pre 84 Trucks 1st gen pickups
Anyone know these 82 radio outs?
Old 12-26-2016, 05:50 AM
1980 Pinellas's Avatar
White is keyed to the ignition and green is ground , those two get the light working on the radio and turn the radio on / off with the key
any chance anyone knows where to hook the other three?
Old 12-26-2016, 11:13 PM
Co_94_PU's Avatar
Show the rest of it, you aren't getting a four channel speaker system working with three wires that is maybe a power antenna. The audio is probably on the din plug hiding slightly off frame. Wiring diagrams on these are either on the cover or under it usually..
Old 12-27-2016, 04:08 AM
I was starting to wonder about that plug , I'm going to go digging around back there but I don't think I have it. Would really like to save the dash , I could never cut it
Old 12-27-2016, 04:33 AM
Old 02-26-2017, 11:04 AM
Ok well
Anyone know where or what this wire does? I'm guessing electric choke, which I have. I was doing to desmoging and when I got done noticed this loose
Old 02-26-2017, 01:17 PM
Fossilized
Staff
dropzone's Avatar
You go from a radio to a carb??
the carb wire is electric choke like you said..
Old 02-27-2017, 02:58 AM
Figured that
problem is there are so many plugs with nothing plugged, hopefully I can find a photo I took of the engine
