FS[GreatLakes]: [MI] 1986 Xtra Cab 4x4 Brown Interior (SR5?)
Here are the SR5 parts and their status. All parts left on the truck are for sale. I'll try to keep this thread updated with what's sold/pending sale.
Instrument cluster - Sold
Tilt column - seems to move freely, steering feels tight
Column clam shell plastic cover - mounting holes are good, looks to be in good shape, no noticeable fading or anything, this is for tilt columns only
Steering wheel - Haven't had this design personally, so I'm thinking it's SR5. Little dirty, but I think it would clean up well.
Door panels and arm rests - these look GREAT, best one's I've had so far, and the design looks really nice too.
Rear cargo basket things - Never seen these in an xtra cab before, rope looks in good shape
Bucket Seats - Driver's side has a dirty spot on the bottom, but overall look really good. Head rests are even in good shape. Driver's side tracks are a little rusty, the passenger side looked good but didn't look it over super great.
Map lights - untested, but the buttons click in / out like normal - pending sale
Info on the truck.
Year: 1986
Miles: 128k
Body: xtra cab
Transmission: W56 (gone)
Engine: 22RE (guy swapped out his bad engine, hole in block, head might be good, has lower efi intake)
Axle gear ratio: 4.10 2 pinion (didn't check if it's a G or not for 8in)
Some extra notes:
Windshield is a replacement that looks to be in great shape, has no trim
Dash pad has a single crack in the middle like most get, center by the window it flares up quite a lot
Has a clock, I have a test harness to validate they work
Has cloth interior, floor matts are pretty trashed, haven't pulled them out to check the carpet.
Last owner drove the truck home, so I know the ECU is good
Reason for parting out, bad frame and last owner bought it for the engine/trans and parted the rest out, I bought the "left overs".
SOLD or GONE parts (I'll try to keep this list updated
Deck Lamp Switch
Instrument cluster (128k)
Center Console
Transmission
PENDING Sales
Headliner
door sills
kick panels
radio trim
__________________________________________________ _____________________________
Second Truck: 1986 4x4 reg cab pickup with 22R (carb) and 5 speed G52 trans (runs and drives yet!). This is the base model so it doesn't have much for special things. The bench seat and door panels have been re-upholstered in dark brown a long time ago (bottom of the bench is worn out), but the back of the seat and door panels are pretty good yet. Truck sat for 11 years in the weather and I had to pull it out of the ground and put tires on it. Really shocked the brakes weren't hanged up too bad. Here's a list of details about this truck.
Year: 1986
Miles: 181k
Body: Reg Cab Short box
Interior color: Brown
Column: Non-Tilt
AC: Yes
Power Steering: Yes
Drive terrain: 22R (Carb) with G52 5 speed and 4x4
Seats: Bench
SOLD or GONE /Broken Parts:
Sun Visors (local sale, has to pick between gray and these brown ones)
Windsheld - Broken
Passenger Dash pad - cracked and faded pretty bad but still there if you want to try to repair it
Rear view mirror - still have it, but it's aftermarket and the back plastic is sun rotted really bad
PENDING Sales
Window Cranks
Door handle trims
Arm rests
Headliner
A pillar trim
door trim (for door opening)
Door panels
Sun visors
rear view mirror
map lights
__________________________________________________ _____________________________________________
Truck 3
Yep got another lol, they keep popping up lately and I don't mind adding axles and such to my collection for play toys. Anyway this one is my first 1987 and there's a ton of slight differences between it and the million 86's I've had. Typical problem, runs and drives but frame is rotted out. This one has a pretty good xtra cab if someone needs the bare cab locally. Anyway as usual here's the details on it:
Year: 1986
Miles: 125k
Body: Xtra Cab Long box
Interior color: Gray
Column: Non-Tilt
AC: No
Power Steering: Yes
Drive terrain: 22R (Carb) with W55 5 speed and is 2wd
Seats: Bench with center arm rest (might be going in another truck that's for the road)
SOLD or GONE parts
JVC Radio
Info on the truck.
Year: 1986
Miles: 128k
Body: xtra cab
Some extra notes:
Deck Lamp Switch
Center Console
Transmission
PENDING Sales
Headliner
door sills
kick panels
radio trim
Year: 1986
Miles: 181k
Column: Non-Tilt
AC: Yes
Power Steering: Yes
Seats: Bench
Windsheld - Broken
PENDING Sales
Window Cranks
Door handle trims
Arm rests
Headliner
A pillar trim
Door panels
Sun visors
rear view mirror
map lights
Truck 3
Year: 1986
Miles: 125k
Column: Non-Tilt
AC: No
Power Steering: Yes
SOLD or GONE parts
JVC Radio
Might be a dumb question but will that gauge cluster work in an 88 4Runner? I know other 4Runner clusters work but not sure about the interchangeability between the trucks and 4Runners. If it does work I want it. Let me know if you know, if not I'll do some research. Shipping would be to 72116.
Thanks!
Thanks!
Thanks!
Thanks!
Appreciate the reply. I haven't checked on this yet but plan to soon. I've got a guy I can call that might know and/or hopefully I can find the answer on the internet. I'm a firefighter and on shift today and my Runner is at home so I couldn't pull the cluster until tomorrow. I've had a hell of a time finding one of these so I hope it does work. I'll get back to you today hopefully with an answer.
Thanks for the help.
No problem at all, wouldn't be much of a seller if I didn't reply .
The SR5 parts are defo hard to find, this is the first out of ~6 86 pickups I've bought. I've had 4 total in all the trucks, 4runners, etc I've had (86 Pickup, 94 4runner, 98 Tacoma, 98 T100). The prices on ebay really reflects how hard parts are to find in good shape.
Well, this site says they're interchangeable.
http://www.siestaoffroad.com/clustertech.html
PM me what you want for it.
Thanks!
Thanks!
Thanks!
Thanks!
Checked the truck and it's missing it, and I just picked up another truck and it's missing it too. I couldn't seem to find any in my parts pile. Do you know if the 89-95 pickup battery hold down is the same? There should be one between the two 2wd pickups I have in that era that I have in mind.
I'm looking for that black plastic trim around the radio/ashtray/cig lighter area. I'm also curious if the combo turnsignal switch assemlby is working and available? What about the box/tailgate on the 2nd truck you picked up?
Thx!
Thx!
The radio trim is slightly shaved where the radio goes in, but is barely noticeable. I'll have to hook a battery up to the truck and see if the lights and such will work, might have to transplant it into another truck to test since this one was stripped down a lot. The guy I got it from drove the truck home, so I see no reason that the turn signal/wiper switch is bad. Does your truck have adjustable delay wipers or the basic off, low, high (the other truck has that style).
I've only had two 84-88 trucks with good boxes and tail gates, and both have been sold to the same guy lol. I have a rusted out long box with a tail gate that works well, so if there's any parts you need off it I could check sections of it out. I also used to had a fiberglass aftermarket box that was rusted out kind of bad, but the guy that bought the other two boxes has it too. If you're somewhat local, I have a few 89-95 boxes that could probably be used to make a good one (some have bad bed sides, others have bad floors) and a 95-04 Tacoma box that's pretty good rust wise but is banged up and has been overloaded and the inside bed is "bellied" as well as the tail gate.
