FS[PacSouthWest]: 84 4Runner 5.3 Swap
84 4Runner 5.3 Swap
Put it on Pirate a while ago, thought I'd give tech a try.
1984 4runner SR5
270k on chassis
5.3 LM7 from a 2006 Silverado 300HP 300 ft-lb
80k on engine
New three core radiator
New Waterpump and thermostat (Common leak fixed)
Nice AGM Battery
4L60E with a NP208 case
2 inch body lift and 4 inch Trailmaster front lift
63" Chevy Spring swap with U-Bolt Flip
Rancho Shocks
15" alloys with 35" Pro-Comp Mud Terrains that have about 75% tread
Landcruiser rotors
V6 Calipers
Stock gearing
repainted about 3 years ago
Custom swing-out tire carrier that is probably the strongest out there
Spare can holder
Hella spot lamps
Classic front tube bumper
3" exhaust with a Magnaflow, sounds really good
Interior has new carpet
LED lights in the rear with dimmer
Custom Reupholstered panels
Rear windshield wiper removed and replaced with an LED camp light (Activated by the Deck Lamp switch)
2013 Impreza Seats
Gauges work except for Tach
OBD2 port
CB Radio
Alpine CD deck
Heater works great
No A/C (only an option in 84)
Small things I would fix since I am really picky:
Front driveshaft I made and always had the intent on getting a professional one made
No center console, was going to put an ammo can in there, but priorities
Truck runs great and will smoke those 35's with little effort. 4WD works perfect and I have taken it on many off-road adventures. I did a 4k mile road trip last summer with no issue. Got around 20 mpg on the highway. Parts are also really cheap for the motor and trans. It has about 20k miles on the swap, so no rickety bang bang stuff going on.
Truck is registered in CA, however you will have to get it smogged if you purchase it. It does not pass as is, there are no cats and it has not been inspected. Now I have done the BAR inspection on an old Starlet before but never tried on this truck as it needs some emissions stuff reinstalled. If you need info on that, just call me.
Selling because I bought a 3rd Gen 4runner and don't need both.
Looking to get $6000.
Located in the Fullerton, CA
Call or text for any questions: 818-272-5748
1984 4runner SR5
270k on chassis
80k on engine
Nice AGM Battery
Rancho Shocks
Landcruiser rotors
V6 Calipers
Stock gearing
Spare can holder
Hella spot lamps
2013 Impreza Seats
OBD2 port
CB Radio
Alpine CD deck
Heater works great
FS[MidWest]: Parts from a 98' 3rd Gen 4Runner Limited
Lance
03-12-2016 04:52 PM
