FS[NorAtl]: LCE W56-C Short Shifter Kit with shifter and base
Up for sale is the short shifter kit I bought for my truck. Before anyone says anything about the price, my price is a little higher because I am including the shifter and base from my transmission with the kit already assembled.
Yes you can buy the kit new for $139. But you can also buy the one I have and keep your stock stuff for easy swap in and out.
I bought the kit for the transmission I swapped into my truck. Shortly after getting the truck running. I found out the transmission was junk. And ended up swapping to a cheap g54 I found locally. So the kit is of no use to me. It has ZERO miles on it.
It will come with the two shifters, base plate, the seat bushings installed, the six extended bolts. I bought a new retainer ring for the tcase shifter which is installed. The shift extension set screws are loctite and staked already. Has some RTV on the base where I installed it.
Looking for $150 plus shipping. Shipping shouldn't be much in the 48. I'll pack it as close as I can.
Hi just wondering if you still have this for sale
[QUOTE=TransAmBandit;52323788]Up for sale is the short shifter kit I bought for my truck. Before anyone says anything about the price, my price is a little higher because I am including the shifter and base from my transmission with the kit already assembled.
80seriesftw
03-05-2016 10:08 PM
