FS[MidWest]: Early 22r block for rebuild! $100
Block, crank, maincaps and oilpan from early 22r. Was used as a hybrid motor with a 20r head. Was a beast till the webber ˟˟˟˟ a screw into it. It is free spinning but needs pistons as the screw embedded into the piston. Funny thing was it still ran awesome, just could hear the screw smackin at idle. May have timing cover and other parts if you need.
$100. shipped on your dime. Will part out.
Thanks, located in St Paul MN
The numbers on the side should say what year no? I'll look into that. I have quite a few parts still. Motor mounts, maybe alternators waterpumps, other ignitors.. Power steering pumps, oil pickup tubes, dipstick tubes, backplates, rear seal, oil pump drive, maybe some oil senders... Pretty much I have parts left over from 20 some engines... Trying to clear out 4cyl stuff. Cylinders have surface rust from sitting.
I'm looking into the cost of shipping now, can you pm me the price of other parts such as Webber carb, headers, or anything you may have performance related. I'm trying to gather parts for my own custom build. Thanks
