FS[SouthCent]: 3.0 V6 Engine Parts. CHEAP!!
Hey All,
Just pulled out my perfectly well running 88' 3VZ out of the Runner to make room for the 5.
All parts are intact and the engine ran like a real champ prior to being pulled, except it was a little 3-SLOW.
Let me know if you have any engine part needs. I won't keep it around too long before taking it to the dump.
7k miles ago I replaced: Timing belt, aisin water pump, NGK plugs/wires, thermostat, belts, and valve cover gaskets.
Located in Houston TX area. Let me know if you need any parts on the cheap.
How much you want for both heads? Am also interested in all the vacuum fittings that attach on the upper intake next to the EGR Tube and cold start injector.
Alright, thanks. I need to mull it over first. Head gasket just blew and I need to verify the condition of my current heads first. Will try to let you know asap.
some drunk guy
08-03-2021 06:09 PM
icentropy
09-10-2015 05:03 AM
EatChipsNow
09-09-2015 01:25 AM
