FS[SouthCent]: 22re part out
22re part out
Parting out 22re engine and anything engine related from a 1986 4x4 pickup. Motor ran fine. Had 200k on odometor but many components are new including one injector,alternator,water pump. Will sell long block or shortblock. Engine had 175-180psi in all cylinders. Will not ship engine. Will ship parts and take payment thru paypal. Pm me your number and i can send pics of whatever you need.
Small run down
Alternator 3 weeks old 60.00
Water pump 20.00
Ps pump 40.00
Cyl head 75.00
Small run down
Water pump 20.00
Ps pump 40.00
Cyl head 75.00
Any idea if the A/C is good? even if the compressor is blown, I just need the bits around it (hoses, bracket, clutch, manifold). I found a local Corolla Compressor that should work, NIB, just missing those things. If you do have it, if you can't confirm the code (10p15c), just confirm whether the compressor bolts are a perfectly square pattern, or if one corner is offset and we will be good. I have the brackets and stuff for the 10p13c (square pattern) if that is what you have.
thanks!
thanks!
steve miller
10-10-2015 01:40 AM
