Toyota T100 Color & Spec Chart
Here is the color and spec chart for the US-Spec T100 from 1993-1998. If you see an error please post it here and I will correct the page and graphic ASAP. You can upload a photo of your car to the site by clicking on the above graphic, then clicking on the appropriate camera icon next to your color.
I will make updates on the chart within a day of any errors or additions posted. To confirm or add your color to the chart just post a photo or description of your car along with the model year (or production date) and the color code. The three-character color code can be found on the production information on a label in the driver's side door jamb.
Yes, I am "the one" haha. I have put a LOT of time and energy into this project for the good of all Toyota enthusiasts everywhere, so I am happy when people tell me they are actually using it!
I have a couple somewhere... I will see if I can find them....
In the meantime, there are some on ebay with some photos... you may can save photos photos and upload. ? Or I could try it tomorrow.
I see that the chassis code of the 93-94 t100 2wd reg cab is vck-10 and the code of the 93-94 t100 4wd reg cab is vck-20. wondering what difference the is in the chassis as I would like to convert my '93 t100 from 2wd to 4wd using parts from a 93 t100 reg cab 4wd.
Well, the chassis codes are really internal platform identification codes that Toyota uses to classify the different versions of a same model. Most likely the actual chassis components are identical or nearly-identical for each truck. Possibly you might have to drill some holes and add some reinforcement parts that the 2WD didn't get, but you shouldn't have much trouble converting a 2WD truck to 4WD as far as using the 2WD chassis components.
...and added a third 1993 T100 commercial to the archive.
Click the 'TV AD' thumbnails under the chart to view the commercials:
http://www.toyotareference.com/t100#T1
Mine is a 1998 SR5. (202). Mine is the only color to have made it all 6 years.
The t100 never had paint fade problems, or rust problems, which is wierd considerding Toyota Pickups built during the time had such major issues with paint and rust. I wonder why?
