FZJ80 springs on 4runner
Old 06-15-2005, 01:27 PM
964runner's Avatar
I have a 1999 4runner 4wd. What do I need to do to fit the front Fzj80 springs in the back of my 4runner. Are OME 2" lift springs for Fzj80 an option aswell. If it would work that would give you 5" of rear lift
Old 06-15-2005, 03:34 PM
Robinhood150's Avatar
The only person I've heard of who did this swap is Bill Morgan
Old 06-15-2005, 03:59 PM
bamachem's Avatar
I have a line on a set and should have them installed in about two weeks or less. if you're patient, then i'll have the info you need...
Old 06-15-2005, 10:29 PM
Jake94's Avatar
What more info do you need? They fit perfect, the only noticeable difference between the 2 coils is the height, ~3.5" lift and work great!
Old 06-15-2005, 10:34 PM
So is this a common thing that I've missed?
Old 06-15-2005, 11:31 PM
964runner's Avatar
my friend has some 1992 landcrusier coils hed give me for like $20. Would these work?
Old 06-16-2005, 03:50 AM
bamachem's Avatar
yup. 1991-1997 are the Fj/FZJ-80 model years. all the front coils will be the same with the only exception being how much they've sagged according to the miles on them.
i would personally prefer some w/a ton of miles and good and sagged. that way, what you get is what you get and they will be good and soft and won't sag anymore...
Old 06-16-2005, 03:52 AM
FilthyRich's Avatar
Originally Posted by Jake94
Nope, It all happened, last month, when Bill_Morgan's 3.4 swap into Red Chili wasn't going to be done b/4 CM this year. Rather than not going we scrounged some parts, from our crazy Russian friend, and pulled a Monster Garage on Mrs Morgan's '97. In 3 days we had a Moab worthy Runner.
The FZJ 80 coils worked so well on his, I'm putting them on my 01.
got any pics??
Old 06-16-2005, 03:58 AM
bamachem's Avatar
Originally Posted by FilthyRich
got any pics??
oh man, i hope he does...
Old 06-16-2005, 06:47 AM
Jake94's Avatar
Yep. I'll try to get 'em posted tonite.
Old 06-16-2005, 06:10 PM
964runner's Avatar
http://motors.search.ebay.com/landcr...fsopZ1QQfsooZ1
Old 06-17-2005, 03:29 AM
bamachem's Avatar
best place to scout out a pair is ih8mud.com (forum).
also, remember that the Lexus LX450 is the EXACT same as the Landcruiser...
Old 06-17-2005, 05:52 AM
KevyWevy's Avatar
can i not read correctly? is it the front or the rear coils that you guys are using from the FJ80's? are you guys using the fronts on the front of 4Runners? fronts on the rears of the 4Runners? im so confused.
*edit*
ok i read that thread on 4x4wire, now i get it. i thought i was misreading the post on top.
Old 06-17-2005, 10:32 PM
Jake94's Avatar
Old 06-18-2005, 09:09 AM
KevyWevy's Avatar
wow, so is that about 3" of lift? what did you use in the front?
Old 06-18-2005, 07:15 PM
KevyWevy's Avatar
nevermind. you said above it was about 3.5" what size tires are those? my friend is looking to lift his 3rd gen and i got some front FJ coils sittin here
Old 06-21-2005, 03:53 AM
ORB
ORB's Avatar
Would this mean that if one were to use a drop bracket lift for the front...then it would be possible to use the front OME coils for the fj80 to lift the back 5" or so??
Old 06-21-2005, 04:01 AM
bamachem's Avatar
i think wha tyou meant to say is that if you used a drop bracket on the front to get about 5" of lift on the IFS, could you then use some Old Man Emu FZJ-80 2" FRONT lift coils on the rear of the runner to get 5" of lift.
i think the answer to that would be "sort-of". you could get 5" of lift from the coils, but then you also have to drop the panhard bar and lengthen your control arms. you'd probally also want to move the frame mounts for the upper and lower arms to get more articulation.
Old 06-21-2005, 11:54 AM
Jake94's Avatar
Are you wondering how they work ???
Old 06-21-2005, 12:26 PM
ORB
ORB's Avatar
Yeah, sorry if it sounded confusing...
I was just asking as it sounded like a possibility for those who want more lift out of their runner without a leaf spring conversion.
I am more than content with my tundra front , it's just that the rear of my 4runner sits lower than the front (I have 891's in the rear). Cruiser coils just might be my next purchase.
Quick Reply: FZJ80 springs on 4runner
