P0121 - Throttle Pedal Switch Position Sensor
Old May 13, 2005 | 06:47 AM
Andrey's Avatar
Last night my "check engine" light came one. Running through OBD-II diagnostics it came up with the following code:
P0121 - Throttle Pedal Sensor Switch "A" Circuit Range/Performance.
Honestly, I'm not even exactly sure where to look. Has someone run into similar issue or is there a place where I can adjust the throttle pedal cable position?
Old May 13, 2005 | 11:27 AM
boogyman's Avatar
Talking
You need to replace the throttle position sensor.. it's on the back of the throttle body.. costs about $80 at the dealership. unfortunately, cleaning it doesn't really help. I had to replace mine at about 60k
Old May 14, 2005 | 05:58 AM
Andrey's Avatar
Is it difficult to replace? When I went to the dealership (had to balance tires), they quoted me over $950 to replace throttle sensor and something else. The guy recommended not to do it though since he wasn't 100% sure if that'll fix the problem.
Can I get in touch with you later on to ask for more details? I'd rather pay $80 and do it myself.
Thanks,
-- Andrey
Old May 14, 2005 | 03:39 PM
Wade's Avatar
Tps
I had the same error, but was able to adjust mine with a feeler gauge. It wasn't that difficult, and after I reset the ECU, the code was gone. Just my $.02
Old May 14, 2005 | 07:13 PM
Andrey's Avatar
If you don't mind me asking, what's the filler gauge?
Thanks,
-- Andrey
smthwsn357
May 1, 2024 07:28 AM
montanatruck
Feb 26, 2017 07:07 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
smiley52
Jul 11, 2015 05:16 AM
