Last edit by: IB Advertising
- Toyota Tacoma Why is Cigarette Lighter Not Working<br>Guide to diagnose trouble and recommended solutions.
Cigarette lighter not working 95 T100
Hey all,
I've searched around the site and found some info about this issue for 4runners, pickups, and Tacomas, but couldn't find a post about it for the t100. It's a new truck to me so I'm just finding my way around everything. Where could I find the fuse for this beast, and is it labeled anywhere? I've also seen lots of talk about a fusible link right behind the socket itself, is that the case with the t100 as well? If so do I need to pull off the front dash to get to it?
Thanks much!
Thanks much!
it could be one of two things.
1) The fuse
2) the wire on the back of the aux. plug. They usually burn up when putting high output products in them. Such as a air mattress pump ( burned mine up a few times ) They're relatively simple to fix. its just a little 12-14 gauge wire on the back of it.
3) buy a new plug.
1) The fuse
3) buy a new plug.
Driver's kick panel...it should be a 15A fuse (blue) in the middle of the bottom row. It won't be named...since the names are on the door...which you probably don't have.
Ok, the fuse looks fine. Going back to Mak's #2 fix, I've pulled out the ashtray and the panel below it but I don't see how to get behind the plug to check that wiring. Any tips?
ashersullivan88yota
01-18-2022 05:37 PM
09-04-2015 09:27 AM
Johntom240
7
07-13-2015 12:18 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
