wireless is driving me crazy - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-16-2006, 09:17 AM   #1 (permalink)
shazaam's Avatar
Send a message via MSN to shazaam
I have a linksys B wireless router and comcast cable internet.
Lately it works for about 10 min and then it will stop working.
the signal strengh is exellent, speed is 11 Mbbs, my network shows up on the wireless list. Then when I click on reconnect, it is unable to establish a connection. Then I'll run back to the modem and the router, and unplug both. Wait a minute, plug in the modem, then when all four lights light up I plug in the router, and then everythign will work fine again for about 10-20 min. Then it will stop working and the cycle repeats itself.
Do I need to go get a new router, or is there something I need to go reset? Or is there somethign wrong on comcasts end.
__________________
Experience is a hard teacher because she gives the test first, and the lesson afterwards.
<-- the artist formerly known as sdastg1
shazaam is offline
Old 03-16-2006, 10:36 AM   #2 (permalink)
Sponsoring Member
midiwall's Avatar
Hmmm... you need to isolate where the problem is. The next time this happens, try just resetting the router. If that doesn't "fix" it, then reset both, and the _next_ time it happens, try JUST resetting the modem.
Once we figure out which one is at fault, we can figure out more. (my bet is that it's the modem, the modem on my DSL line does similar things).
Is the network ONLY wireless, or do you have a wired node as well?
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 03-16-2006, 11:36 AM   #3 (permalink)
Churnd's Avatar
Send a message via AIM to Churnd
You might also need a firmware update. But you do need to isolate the problem as midi said. I've found an easier way to do it is to just plug your machine up to the modem and browse for 10-20 mins and see what happens. That'll tell you whether it's your router or not.
If it's the router, update your firmware. Find your model here:
http://www.linksys.com/servlet/Satel...VisitorWrapper
and follow the instructions.
__________________
-Chris
If you can't explain it simply, you don't understand it well enough.
Click here to search!
My Website
Churnd is offline
Old 03-16-2006, 12:23 PM   #4 (permalink)
Jeffires's Avatar
Send a message via AIM to Jeffires
Cable modems sometimes act this way when overheating. Like Mark said, try your setup with just the cable modem to determine if it is working properly.
EDIT: What type of cable modem is it?
__________________
-Jeff-
'91 4WD P/U 3VZE A340H , 197K
K&N air ] Optima ] Flex-a-Lite fan ] FloPro exhaust ] ISR Mod ] Warn M8000 ] Powertrax lockers ] Swaybar Discos ] KC Lighting ] Premier MP3 - Pioneer highs/mids - RF DVC 12/ RF 360a² ] Garmin GPSMap60C
Photo Album
MySpace
La Nouvelle-Orléans
'da Ragin Cajun
Jeffires is offline
Old 03-16-2006, 01:13 PM   #5 (permalink)
89macrunner's Avatar
linksys does make a good product if you buy one thats not defective. I sell those at work all the time and we get them returned all the time because they just dont work. since its a b router im guessing its not new...talk to linksys and try to get a warranty replacement. If you can't do that pickup a new router
__________________
Daily Driver: 2007 Windsor "The Hour" Fixed Gear 250 miles
Crouch Rocket 2005 Felt F80 1100mi (purchased new in Jan 2008)
2006 Mazda3 GT
2000 TRD Tacoma..Bought back and crushed
1988 4Runner SR5 V6 5 speed..sold
89macrunner is offline
Old 03-16-2006, 01:50 PM   #6 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
you might try a diffrent channel on the wireless... if your sharing it with another wifi point you might be having conflicts and it boots you off...
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 03-16-2006, 07:14 PM   #7 (permalink)
shazaam's Avatar
the modem is motorolla unit.
I have the main computer hooked into the router in addition to the laptop on wireless.
I will try to isolate the modem like you guys suggested.
thanks
__________________
shazaam is offline
Old 03-17-2006, 03:01 AM   #8 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
Need model # too.
A lot of modems are no longer compatible with Comcast.
I just went throgh this a few months back.
Good connection, then it would cut out, come back, loose it again.
Narrowed it down to an antique modem.
Installed a new Motorola 5100 Surfboard, now I get close to 9 megabit service while paying for 6, and it never cuts out.
Corey is offline
Old 03-17-2006, 07:04 AM   #9 (permalink)
arjan's Avatar
Do you have to buy your cable modem from the company which supplies your cable service, or will any modem work? I was wondering if your cable provider puts specific settings into your modem or that's all done on their end and any modem will work.
__________________
2006 4Runner V8 Sports Edition
Red 1997 4Runner 3.4L Bushwacker Flares, 5spd, E locker
arjan is offline
Old 03-17-2006, 08:46 AM   #10 (permalink)
Churnd's Avatar
Quote:
They do "cap" the modems to limit bandwidth. I'm not sure how they do it, as some do it on the head end of the ISP... in other words, you can't do anything about it. Read up on uncapping your modem here: http://cable-dsl.home.att.net/
Any modem will work. I bought my Surfboard from Best Buy when they were having a rebate deal on signing up with Comcast. After the rebate, the modem was free, and I got a $75 gift card for Best Buy. Score! So yeah, any modem will work. They block modems via their MAC address, so if you buy a new one, you'll have to get the MAC address registered.
__________________
-Chris
My Website
Churnd is offline
Old 03-18-2006, 08:47 PM   #11 (permalink)
^VooDoo^'s Avatar
Heres a quick test you can do
Once the connection is made, Go into adminnistrator tools/component sevices and click services, down at the bottom find (zero wireless configuration) click stop
and wait and see what happens, If it drops you have to restart or reset machine or windoze doesnt try to reconnect.
2 things happen sometimes in windoze, 1. windoze likes to seekout new connections and can cause disconnetion. 2. Low level reception spikes can cause same thing.
Ive had a few wireless B's that had have this done sometimes
Also keep the semi-line of site clear of flourecentlights,wireless phones and picturetubes.
^VooDoo^ is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22re driving me crazy! John79 86-95 Trucks & 4Runners 11 04-18-2009 05:06 AM
Help! YouTube driving me crazy rubysRunner Computer Talk 21 02-18-2007 04:25 PM
Alarm system driving my crazy drguitarum2005 Alarm Systems 2 11-26-2006 09:38 AM
Overheating driving me crazy WillRadford 86-95 Trucks & 4Runners 10 07-21-2006 09:12 AM
This knocking is driving me crazy!! DH6twinotter 95.5-2004 Tacomas & 96-2002 4Runners 8 01-27-2003 09:46 AM
2009 InternetBrands, Inc.
