| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
WEP vs WPA-PSK wireless security?
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#2 (permalink) | |
Quote:
If you have the WPA set-up already leave it be. Basically WEP is an encryption algorythm that has flaws and WPA was originally designed to be part of a system of security that uses RADIUS authentication. The PSK part of your WPA is the "Pre Shared Key" between your wireless AP and your PC. Under normal circumstances, the WPA authenticates you through a RADIUS server. This is usually an Enterprise type system that gets expensive. Instead of the RADIUS server you share your security keys locally. So Basically, you've taken some steps to secure your Wireless stuff, put a firewall on your network, either software based or a hardware type and your ok as far as most kiddies trying to hack your network. Remember, most security breaches are from the people who are authorized to use your network or PC. Don't download files your not sure who they are from,,,,,etc...etc...etc...... MV
#3 (permalink) |
My D-Link router (DI-524) seemed to have a decent firewall already setup (maybe you guys can look at the specs and let me know what you think..... http://www.dlink.com/products/?pid=316 ) but I am still working on the config part of it. Only part I was not sure about was if I should set up the router to deny ping request?
__________________
#4 (permalink) | |
Quote:
Use the MAC filtering and block ping requests. Then go to GRC.COM and use shields-up to check you settings. MV
| Tags |
| addresses, flaws, network, psk, router, security, v, vd, versus, vs, wappskl, wep, wireless, wpa, wpapsk |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wireless Security Through OpenVPN | arjan | Computer Talk | 2 | 02-22-2006 07:43 AM |
| Internet security | Mad Chemist | Computer Talk | 20 | 08-20-2005 02:23 PM |
| Wireless SECURITY WEP is VOLUNERABLE | amusement | Computer Talk | 8 | 01-07-2005 03:26 PM |
| Security code?! | venturanova1 | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 05-22-2004 02:54 PM |
| I need to go wireless.......Help. | GRNTACO | Off Topic Talk | 9 | 05-18-2004 05:01 PM |
