Tach not working
Old 08-16-2014, 05:24 PM
Yotav6power91's Avatar
Tach not working
Have a 91 toyota pickup 3.0 and the tach does not work at all have no idea what the problem is. Thought it was the tach it's self but got a used one from the junk yard tried it and still didn't work. Iv tested the signal coming out of the distributor and the signal is strong from there but were else does the wire go to from there before the tach? Could it be the ecu going bad? Any help on any info on the tach would be helpful thank you
Old 08-16-2014, 07:33 PM
Staff
Terrys87's Avatar
I dont know if you are adding the tach or had one before, but you can run a wire from the ground side of the coil to the "p" on the back of the cluster. Not all trucks are wired for the tach in the harness for some reason.
Back of guage is marked with a "p".
Old 08-17-2014, 10:13 AM
My back of the cluster doesn't look like yours but it came stock with the tach it just stopped working
Old 08-17-2014, 10:53 AM
Staff
DeathCougar's Avatar
Why is this thread in computer talk?
Old 08-17-2014, 11:07 AM
Gamma_Hugo's Avatar
run a wire from the negative wire of the ignition coil to the "P" screw in the back of the cluster gauges. I just swapped mine from a 3 gauge simple version to the SR5 cluster and it worked for me
ashersullivan88yota
01-18-2022 05:37 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
Quick Reply: Tach not working
