scanner problem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-04-2005, 02:19 PM   #1 (permalink)
Glenn's Avatar
scanner problem
Hi
I have a Visioneer 8900 USB scanner used mostly for scanning prints.
The problem is that it sometimes puts a pink streak across the picture near the bottom. It goes across the entire image and is about half an inch side. Usually a rescan will get a scan without the pink streak, but sometimes I have to try rescanning several times.
Anyone know what causes this and how to fix it?
Thanks.
__________________
-Glenn-
Glenn is offline
Old 02-06-2005, 07:16 PM   #2 (permalink)
photoleif's Avatar
Send a message via AIM to photoleif
no guarantees here, but often the pink streak is caused by a corrupt jpeg file. try scanning directly to a non-compressed file format such as .tif, and see if the problem persists. also, is the streak in precisely the same place every time, or does its location vary? if it varies, then it's not necessarily the scanner itself, but perhaps the cable. if you have a different USB cable you could use temporarily, try that (if the location of the streak varies).
__________________
'95 Xtra cab 3VZE SR5V6 | 33x10.50-15 BFG AT/KOs | 4" Superlift | OME torsion bars | Total Chaos idler arm and uniball | Rancho steering stabilizer | Smittybilt front & rear tubular bumpers | Sportsman topper | Aisin hubs | Dual Optimas | Extended diff breathers | Custom center console
sometime: rear locker
some sometime: retire the IFS
My truck page
Photography:
http://www.aspen-graphics.com
photoleif is offline
Old 02-07-2005, 11:04 AM   #3 (permalink)
Glenn's Avatar
It's always in the exact same place. I will try a different format if I can. Thanks for the response.
__________________
-Glenn-
Glenn is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
CB with scanner?? Parsh GPS & Communication 8 01-11-2006 12:36 PM
Scanner Install Tim-in-TX GPS & Communication 5 01-02-2006 05:18 PM
scanner SteveO 95.5-2004 Tacomas & 96-2002 4Runners 7 06-06-2004 07:47 PM
Diagnostic Scanner 98RNNR 95.5-2004 Tacomas & 96-2002 4Runners 0 02-06-2004 08:34 PM
2009 InternetBrands, Inc.
