rundll.exe - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-06-2004, 08:41 AM   #1 (permalink)
RED 85's Avatar
Question rundll.exe
I deleted my rundll.exe is there a way i can get it back?
__________________
Brandi
You heard of the boy named Sue, Well I'm a man named Brandi!
'85 extra cab pick-up, Up on blocks waiting for time and money.
'85 4-runner with 3" lift, 33's, 4.88's, rear ARB (still trying to get air to it), Downey intake with K&N filter, some type of header, Camo Int.
RED 85 is offline
Old 09-06-2004, 02:18 PM   #2 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
Get 'em here
http://www.dll-files.com/
It is a safe site.
Corey is offline
Old 09-06-2004, 03:39 PM   #3 (permalink)
RED 85's Avatar
Nope thats not it. I don't need dll files i need the rundll.exe the one to run all the program dll's.
__________________
Brandi
RED 85 is offline
Old 09-06-2004, 03:49 PM   #4 (permalink)
Staff
Corey's Avatar
You running XP???
Which folder is it in, and I can give ya a copy of mine.
Doing a search on my system, I am getting a few hits, but they are named slrundll.exe instead.
http://www.pnw4runners.com/temp2/dll_search.jpg
Corey is offline
Old 09-06-2004, 05:21 PM   #5 (permalink)
RED 85's Avatar
I am running XP pro what is happening is everyprogram that I try to open says:
Windows cannot find(what ever file name of program). MAke sure you tayped the name correctlly and then try again. To search for a file, click the Start button, and then click Search.
And I know that the programs are installed but it also happens with windows update and other windows based programs like calculator, notepad, wordpad, anything except Outlook and IE.
__________________
Brandi
RED 85 is offline
Old 09-06-2004, 05:58 PM   #6 (permalink)
WT
WT's Avatar
Sounds like it maybe a case of spyware/adware trying to load prior to any apps, try scanning your system maybe worth while to also check for a virus.
Did you do any cleanup of startup items recently ? add any new software ?
__________________
96 4Runner SR5 SC | 3" Revtek Front/OME 891 Rear,Diff/Panhard Drop|AirLift bags|285/75/R16 Nitto Terra Grappler|Eaqle 121 w/TRD Logo|Bilsteins|Cross-Drilled PS w/PF Pads|Silver Reverse Gauges|Custom Grill|Catch-All Floor Mats|Sylvania SilverStar|Weather Tech Visors|Clear Corner/Fronts|Alpine MP3/WMA/CD|99+Headlight/Console Mod|K&N FIPK W/Drycharger|Optima Redtop|Trans-Cooler|Remote Start|PICS|PICS2|
WT is offline
Old 09-06-2004, 06:39 PM   #7 (permalink)
RED 85's Avatar
Yeah to all I know i had spyware/adware problems so i cleaned things up and added some programs to help with that. I think that i deleted to many files in my system and system32 folders. I tryed repairing with the windows cd and there was a list of system32 files that were missing and it still won't let me open anything.
__________________
Brandi
RED 85 is offline
Old 09-06-2004, 08:17 PM   #8 (permalink)
WT
WT's Avatar
Are you sure its rundll.exe ?? I can't find any file names rundll.exe on my computer and I am running XP pro also. there in a windll32.exe in my windows/system32 folder.So if its still looking for rundll.exe I still think there a piece of the spyware left behind and you actually deleted the spyware program that was used to track your file usage and loading that prior to loading the real program like notepad and such. This is all speculation at this time without being in front of your machine to look around the registry. Do you remember what spyware or addware program you found may help with removing the last part of it that maybe still stuck in there some where.
So if you just need the rundll32.exe file leave me were you like me to email it to you at.
__________________
WT is offline
Old 09-06-2004, 08:34 PM   #9 (permalink)
Staff
Corey's Avatar
Have you tried also going back in time and using a System Restore point from before you started to delete files?
That may fix it.
PS, I do have a rundll.exe file as seen in my MSconfig running, 2nd down from the top.
http://www.pnw4runners.com/temp2/rundll.jpg
But it is part of a program called Tweaki which is a lot more enhanced than the Miscrosoft Power Toys "TweakUI" program.
Corey is offline
Old 09-07-2004, 06:20 AM   #10 (permalink)
WT
WT's Avatar
Quote:
That may fix it.
System restore would only gain him a fix if its something in the registry but its starting to sound like he just accidently deleted to many files during some cleanup in the system32 folders. Plus in your case cory it looks like Tweaki is calling the rundll32.exe and its nto a standard startup item, cause I don't have it loading on any of my machines and I run mine pretty clean and lean.
If all else fails you could always try a in place repair(re-install) of XP it will revert the OS file systems back to orginal dates of the XP CD you have granted you have a actually CD and not a rertore system CD from a manufactur type cds. Here take a look see if this is something you may want to try next, I have done it several times on a few machine with no problems only thing is you will have to run all the updates again since it will remove those files, plus it says make backup of important things just in case...
http://support.microsoft.com/default...&Product=winxp
Oh another option just popped into my brain, is just restore a single file from the CD, worth a try also before the re-intsall in place option:
Good Luck !!
__________________
WT is offline
Old 05-12-2008, 01:04 PM   #11 (permalink)
windows cannot find rundll.exe
I used to have a similar problem. This windows cannot find rundll.exe solutions summary page helped me. Whiel its beginning contains some advettising fluff, skip it all and scroll to the bottom. The you'll find what htey call a manual slution methods and it worked for me.
Other possibility if that you have your real rundll.exe file corrupted. In suhc case I recommend you to run sfc.exe /scannow command from Start->Run dialog. It will search for corrupted files and recover them from your Windows CD. Good luck!
James Abilton is offline
Old 05-12-2008, 01:06 PM   #12 (permalink)
Tags
78exe, 89exe, 96exe, clear, computer, find, program, real, rundll, rundllexe, slrundll, talk, tracks, windows, xp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Lass.exe bad?! computer restarting on its own. Tofer Computer Talk 1 01-25-2006 06:30 AM
! ! ! msmsgs.exe possible worm. 4-RUNNIN' FREAK Computer Talk 0 09-22-2005 08:14 AM
aveula.exe - WTF! ARGH!!!!! Cebby Computer Talk 4 08-02-2004 07:46 PM
2009 InternetBrands, Inc.
