| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Question about Isolators, Invertors an Batteries...
#2 (permalink) |
The alternator is just the source of charging for the batteries, so assuming you have some sort of battery charger, that would take the place of the alternator. If the batteries are always going to be sending power to the PC, then you can just hook up a pair in parallel (w/o the isolator). Isolators are of must help when the batteries are just sitting there, keeps one low battery from sucking charge from the higher battery. Get two deep cycle batteries (or one bigger one) and hook it up. How long 1 or 2 batts. will last is determined by how much load you have (how many Amps) and how much reserve capacity the battery(ies) have (Amp Hours). To figure out how long it will run, divide Amp Hours by Amps and that will give you an idea how many Hours the battery will last.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
